Leveling kit recommendations
Bigbendmoe628
Maurizio
Long Island
Hello everyone what’s a good leveling kit thanks
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
I'd like to do it too, was so easy to add 1" to the front of my GX using spring pucks, but heard the job is not so easy on the Bronco.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
I heard that is a PITA to install, is that true? Spring compressor needed?
It is the easiest lift one can do on these rigs. It is a 1.5:1 ratio on the front and you can put the upper spacers for a 1:1 on the rear. Only have to lift, remove the top tower bolts, the two lower bolts, and good for a front level. May have to disconnect the upper ball joint and steering rod, for room to move around, but do not have to mess with compressing the coil over. The 1 inch level kits that are out there are typically 1/4 inch spacers, with a few that are 3/8. This will give a 3/4 to 1 1/4 inch lift on the front. The prices run 35$ to 200$ depending on whose name is on it. Rough Country has two 1/8 upper spacers so you can go 3/4 or 1 inch on the front level.
If you do a 1.5 to 3 inch, it is a spacer on top that you rotate the entire coil over on non-Sas, but will need to compress and turn the upper plate slightly to align the bolts on top for the Badlands and Sas. The Bilstein's are indexed due to the reservoirs.
Easy peasy.
box986
Paul
NNJ/NEPA
Easy peasy.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
We have two great choices for leveling kits!
Eibach makes a great leveling kit if you want to maintain close to stock ride height and similar ride quality, with some improvements on small-bump compliance.
