- Adam
- Aug 30, 2021
- 555
- 6,159
- 7,050
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Not sure if you guys have heard of Kingpin but I wanted to take a moment and tell you about their products. They make these awesome 12" and 40" light bars that are designed for interior cargo/work light use. We know that there is NO LIGHTING in these Broncos so a 12" bar in the back (or two) is an awesome addition to have. The bars have mounting brackets included that you can either screw in or use the included adhesive tape. They can easily be connected to the rear cig plug so that you don't have to bother running any wires. They have two styles available
The V-Series lights throw a slightly narrower light beam compared to F-Series lights. The lens is narrower. This can provide more isolation and less bleed into other areas where you may not want light.
The F-Series light beam is wider than the V-Series beam. The lens is wider. It also features a built in on/off switch AND a toggle switch allowing the light to change from white to red.
You can either wire these bars up to a cig. plug (and use the rear cig. plug) OR grab one of their switches to have an on/off switch wherever you want.
Available Here: https://www.4x4truckleds.com/kingpin/
