Kicker replacement sub 6.75
Area51Ma
Jimmy
Boston Ma
Cadillac srx4
While still using the stock B&O amp and wiring to original paper speaker ,and just replacing the speaker itself ,should I order dual 2 ohm..or dual 4 ohm ... Thank you
Draughon
Daylon
Dallas
BMW 4-Series
I dremel'd the stock enclosure and fit a Kicker CompR 8'' in the space - but at full power I strongly believe it's over-powered for the available air volume so I'm getting a sympathetic vibration at certain frequencies.
Ordered the Kicker 6.75'' 4ohm version that should come in today and I'm going to swap it out to see if that's the issue.
Ford Bronco Kicker replacement sub 6.75 1713361637793-df
Area51Ma
Jimmy
Boston Ma
Cadillac srx4
Please add results to this thread ...and ty
B&O uses a 4 Ohm dual voice coil woofer. Standard 7-channel uses a 2 Ohm dual voice coil woofer.
It won't break if you use the incorrect ohm, but best if you can match it up.
Area51Ma
Jimmy
Boston Ma
Cadillac srx4
Thank you sir ...was able to stop shipment of the dual 2 ohm..and replaced with the dual 4 ohm this am .. I knew there was a difference between B&O and standard 7 ...but you confirmed it
Johnny Mo
Westchester County, NY
teachu2shoot.com
You don't need to dremel the B&O enclosure at all to fit a Kicker 8". You just need to remove the kicker beauty ring from the front perimeter of the speaker. There is also a very small centering tab on the bottom of the enclosure that needs trimming but the can be done with a simple xacto knife.
The Kicker Comp R 8" dual voice coil 4 ohm fits just fine and when wired in parallel will run at 2 ohms and mated to a kicker key 500.1 at 300 watts is absolutely a perfect replacement. I am thrilled with my setup even with top and doors off.
Scroll to the bottom for sub pics
https://photos.app.goo.gl/JK9DzkcMWQaB368UA
This is true for B&O enclosure. The standard 7-channel you do need to cut the opening a bit wider to fit an 8”.
Odd they used a different speaker and enclosure but the same sized speaker. I wonder if there are other differences, like volume or port size
Cordycord
Cord
SoCal
2016 Pilot, 2016 E300, 2005 MSM, 2001 B3500, 2010 Range Rover Sport, 2022 Pilot
Ford Bronco Kicker replacement sub 6.75 IMG_5275
Ford Bronco Kicker replacement sub 6.75 IMG_5059
I had every intention of swapping my 6.75" stock woofer for a Kicker 6.75". But I'm also bi-amping the front four speakers with a Kicker 200.4, and I already added coaxial Memphis 6.75" speakers to the back, with larger pods.
BTW, the stock woofer for a 2025 Heritage (7 speaker setup) is 110W, 2 Ohm and is run in parallel (2+ 2- connectoins) for 1 Ohm total. The speaker itself sounds great, looks great, and is pretty much the same weight as the Kicker. If I upgrade, it will be to something mounted on the tailgate, and I want to see if there's a difference after Forscan. Anything larger than a 6.75" mounted in the stock location needs to go through a 6.75" plastic vent. I can't square that circle.
Last, once the front speakers are set up, Forscan is run (you can see the numbers below), and the Memphis coaxials are set up, I'll have a better idea of how much woofer I'll need.
Ford Bronco Kicker replacement sub 6.75 IMG_5276
Ford Bronco Kicker replacement sub 6.75 IMG_5277
