ShortBus.cle
Cleveland
@Aurongel
Running it to the battery wasn’t too bad, especially if you mounted the amp on the drivers side. I had a wiring kit from crutchfield that helped. I’ll try to take some pictures today.
Depending on the song it was clipping at as low as volume 12. I also am going to do my own grounding wire too, I’m getting some noise when no music is playing.
Sherminiator
CNJ
2022 Ford Bronco Big Bend, 2024 Bronco Sport Big Bend
Great photos! I just ordered another cable and inline fuse to wire up the Key200 when I go to install it. I'm just waiting on the B&O sub enclosure to show up so I can get started...though I might just put the Key AMPs and speakers and leave the rear cargo panel off till it does show up.
Sherminiator
CNJ
Mine came with a note in the package with the wiring diagram. I can take a picture but it was handwritten and may not be the same
This is what I got in mine-I see no reason why it should be different for each harness
@BFizzy
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! 1655466420185
I just modified the harness that comes with the Key500 using that.
Sherminiator
CNJ
So super stupid question-when you cut the wire to the fuse, did you do it the side closest to the large plug (to the left) or the other side-I'm assuming the large plug but just double checking and I haven't actually put my head under the dash yet.
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! 1655466723290
mcinfantry
Lee
Louisiana
Badlands 2 door
Is it possible the wire nut instead of solder isnt a good connection and may cause issues? I was always taught wire nuts are never good for connections that vibrate or stranded wire (auto)
ctandc
VA
'22/23 Bronco, 96 EB Bronco
I MAY do the same thing, since I'm waiting on an add-on harness and Kicker hideaway sub. After following the setup below, I don't have any clipping at a volume I'm willing to try at least.
1. Reset the amp to default setting (hold the mic button down for 10 seconds - you'll hear a long beep).
2. Turn the amp gains ALL the way down (CCW)
3. Set the head unit EQ (Treble, Bass, Mids) where you WANT it.
4. Play the Kicker pink noise and turn the volume up until you see the LIMITER LED, then back the volume off one click - that's your MAX volume
5. Run the Kicker DSP setup with the pink noise on your max volume setting
6. After setup completes, click the mic button once, pink noise starts again. Now w/ pink noise playing at the SAME volume, turn each gain up until you hit the limiter LED, then back it off a bit.
7. Test the sound and see what you think.
After doing this - this thing goes WAY louder than I'll ever play it with no clipping.
The only reason I may consider running the Kicker power wire to the battery is simple - I have to add pins / wires to the existing harness anyway to install the Kicker Hideaway sub, so I'll be in there and harness will be out. I also have to run power / ground for the sub as well.
Honestly if I do it, I'll depin the amp power wire from the plug n play harness completely and run it to the battery and rewrap the harness.
Biff
Southern WV
2016 Honda CR-V AWD SE
@BFizzy
Thank you very much for posting the pic of the wiring harness note, as my PNP Kit 11-4 did not include one. I will be attempting to add my Kicker 11HS8 this weekend. I currently have the Kicker Key 200.4 installed and it sounds amazing with the four 4” Infinity Reference speakers I swapped to in the dash and rear pods, but cannot wait to round out the sound with the sub!
ShortBus.cle
Cleveland
Yes you want to cut it on the side the Amp is on, not sure if that’s the large plug or not.
ShortBus.cle
Cleveland
Yeah that’s a good point. The wire nut solved the clipping problem for me so no issues so far. If I do get an issue that will be the first thing I check!
Sherminiator
CNJ
So I did my install yesterday-replaced all the speakers and installed the key200.4 amp. Still waiting on my B&O sub enclosure to show up, then I'll add the Key500 amp and a kicker 8in sub to.
I ran the EQ test this morning and played around with the gain and other settings.
Overall I'm happy with the improvement I got-the mids and highs are worlds better then the stock speakers, but I'm disappointed with the bass out of the kick panel speakers-I thought I would get a bit more bass out of them, but they don't seem to be all that much better then the stock ones. Any ideas on what to trouble shoot with that?
The other thing I noticed is that rear speakers are much louder then stock and seem to put out more bass then what I'm getting up front. I don't have bass blockers on them either, is this normal?
Biff
Southern WV
I stuck with the stock speakers in the kick panels as they sound pretty darn good now after installing the 200.4. The Infinity Reference in the 4” locations sound crisp, clear, and loud now, especially after I bumped the rear gain up to about 4/11. I did install 300 Hz bass blockers in the dash speakers, but not the rears as the head unit seems to limit any bass going to the rears at all. If time permits tomorrow, I’m going to install the Kicker Hideaway 8, thanks to your posting of the note from the PNPK 11-4 wire colors.
Barlos
Carlos
Menifee, California
Tahoe
Same here , I think spending $300 on kick panel speakers that sound not as good as the original ones was probably a bad move. Other than that Im happy with the install, one con is that the sub only sounds good when is at high volume. Low volume sounds like rattle of popping.
BFizzy
B
GTI
I made almost the exact same decisions. Four Infinity Reference 4”s. 300hz filters on fronts, none on the rears. Kept the OEM 6.5s. KK200.4 with pnpkit 11-4, but I went with the kicker 46hs10 hideaway. At times you can tell the 10” is in a ridiculously small enclosure, but ultimately the sound is great for the practicality.
Biff
Southern WV
I was seriously torn between the 11HS8 and the 46HS10 since Crutchfield had them both on sale last month. Hopefully the 8 will be plenty for my needs, as ANY bass will be most welcome to fill it all out.
