Kicker Key 200.4 w/ PLUG&PLAY Harness....
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So.......WOW. I didn't expect the difference to be this good :) I was apprehensive at first to spice and dice wiring, but Plug & Play.com has a harness that makes this SO CRAZY EASY:
https://plugnplaykits.com/collectio...y-audio-harnesses-kits?variant=41157659852990
They have an install video on that product page, scroll down.....I did, however, opt to install the amp underneath the steering column. Zip ties - BOOM. Done. Easy Peasy. Plug in the DSP microphone, play test tones - DONE. Completely better and clearer cabin music!!! Note that I do have aftermarket speakers - but no sub. Still sounds amazing. I had the speakers installed for about two months now and the difference with that tiny amp rocks.
This is another Install Video I watched:
Here is where I mounted it:
Ford Bronco Kicker Key 200.4 w/ PLUG&PLAY Harness.... IMG_4408
Ford Bronco Kicker Key 200.4 w/ PLUG&PLAY Harness.... IMG_4409
22OBX
Hartford, AL
Good job! They are nice but the Key install and results is on every other thread in the audio section. Same as what many have already done and reported.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Correct - this is where I got most of the reviews and info :) SUPER helpful, especially with the video links. Just my own 2 cents really.
nwGTS
Nate
Chicago, IL
Love seeing these installs. Thanks for posting!
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
Wait so the wiring harness is $150?! Ugh, just got my kicker key today and trying to get a harness for it.
Saw a video that used a Hoel harness, but its not on their site. Emailed them about making me one.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
With the trouble that guy went through to get all that done......I did think about it - and the cost is fair granted he literally made it Plug & Play. Splicing all that would have been a nightmare, unless you are really good at it.
fallguy
Tennessee
I suppose, and I am not really good at it. I guess I just assumed a harness wouldn't be almost as much as the amp when I bought it. People been doing this over a year now, usually prices go down and more people copy cat. No luck so far though.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
The PNP harness is more of a “how much is your time worth” kind of product. For me, I wanted to get in and out as quick as possible and also not do any taps. It’s a time saver and a reassurance thing.
nwGTS
Nate
Chicago, IL
Agree the price is worth it. Just bought the 200.4 + 500.1 + harness today. Awesome to have a DIY turn key solution for terrific audio in the Bronco.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
My next will be the 500.1 at this point. Was going to get a self powered sub, but I'm just going to likely do the stock B&O enclosure with a kicker sub and the 500.1 + Harness.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
First post I've seen mounting anything to that bracket, better than notching glove boxes, etc👍
nwGTS
Nate
Chicago, IL
This is exactly what I did. Kicker 8" shallow compRT, OEM B&O enclosure, wired to the 500.1 (once it comes in). The trick now will be chasing rattles. Good problem to have! :)
jshapz
Jonathan
AL
4D
If you haven't done the install yet, you can fit the full size 8in in the box and dont have to use the shallow. Now I don't know if its worth your time to return the shallow or if the full size is even better but just wanted to point it out. Also I haven't been chasing any rattling thank god. I just felt tape wrapped everything I could with the panel off. Wrap the plastic clips on the trim panel side too. I took the clip off and wrapped the base of them, makes putting that clip back into the trim harder but just shove them in.
I'll install my key 200.4 in a few weeks when I'm done traveling but I can tell you the sub is absolutely worth it. Turning the bass knob all the way down feels so bad, there is no comparison.
CADUC3US
Christopher
Kansas
2021 Bronco / 1997 F150
I plan on getting the Kicker Key 200.1/PNP harness/upgraded speakers soon but as someone with little knowledge about car audio what would you suggest I do to be ready for a small sub (8" or 10") at a later date? Is there another harness/cord I need to install for a sub...I want to open the dash only once to avoid breaks/rattles. Any other bits of knowledge to "future proof" that install would be appreciated.
RagnarKon
Ford Bronco, Escape, Focus
Many of the "plug and play" harnesses that are built for the Kicker Key amps also come with provisions for the Kicker HS8/HS10 subs. So that is probably what I'd go with unless you are comfortable cutting into harnesses and whatnot.
