KICKER KEY 200.4 IN STOCK .
plugnplaykits
Ct
Kicker key 200.4’s are now in stock . pre-orders started shipping today.. kicker key 200.4 are now coming with a power kit that includes 12 gauge power wire fuse in fuse holder, and the amp must be connected to the battery and no longer off the radio’s power .
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Why the change in power harness?
plugnplaykits
plugnplaykits
Ct
When not hooked up directly to the battery. The amp could clip at high volumes.
Medicin3man
Frank
‘23 Braptor, ‘23 Telluride 4x, ‘10 FJ Cruiser TT
I am confused what this is. I upgraded all my speakers to kickers, I have a 12” subwoofer in the back hooked into a 1000w kicker amp and have upgraded the harness. I still would like to get more power out of my head unit. IS this what that is for?
plugnplaykits
plugnplaykits
Ct
Yes, it’s a small amplifier to amplify your interior speakers, but if you did a 12 inch subwoofer with 1000 W kicker amp, the kicker key is too small of an amplifier to drive your interior speakers with that much bass you need to use my musway four channel amplifier to balance out that system
Duvel
Overland Park, Kansas
Toyota Land Cruiser, Range Rover Sport
Back in June, I purchased KIT 11-1 KICKER KEY 180/200,4 HARNESS ONLY.
Can I just unwrap the harness, snip the power and ground wires and run them directly?
No clue what I'm doing, so want to be certain it might be as easy as that.
HotdogThud
mk6 gti, '21 MoarDoor
I've noticed this exact scenario, usually at about 18+ even with the gains turned all the way to zero. would be nice if the fix was as easy as that
plugnplaykits
plugnplaykits
Ct
HotdogThud
Bubbbba
Ohio
None
plugnplaykits
plugnplaykits
Ct
What you need to understand and this is a common misunderstanding by everyone is that the gain adjustment is not a volume knob it’s to adjust input sensitivity when using high-level input ( factory radio ) you’re already getting a strong signal 6-8 volts as opposed to using RCA‘s 2-4 volts from an aftermarket radio . the amp puts out the same amount of power whether the gains are off or all the way up . So when you’re already getting a strong signal when you turn the gains up, you just freaking out the amplifier and start introducing noise, static, and other issues into it. . Gain should be at best a hair up from off .
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Hot damn! thanks!
ordered.
I'm very interested in this as well. When you receive yours and get it wired-up direct to the battery, please share your results. I'm clipping around the 13-16 mark depending on the song. Thank you.
HotdogThud
You're close by, I'll just let you have a listen
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
gutshot
Kelly
ohio
2023 Bronco
