- First Name
- Bryan
- Joined
- Aug 5, 2021
- Threads
- 41
- Messages
- 5,492
- Reaction score
- 14,580
- Location
- New England
- Vehicle(s)
- Ford Bronco, Escape, Focus
- Your Bronco Model
- Badlands
Bi-Amp mode basically enables the Kicker Key 200.4 to work as a component speaker amp. One larger speaker that plays the low-medium frequencies, and another smaller speaker than plays the medium-higher frequencies. It's a very common setup in audio.So I'm a little confused. I have the 200.4 and used a harness from plugnplaykits.com
This is the way I set mine up and worked well:
1.) Bi-Amp Mode OFF
2.) Fader ON
3.) Radio Detect Button -Verify Pushed In
4.) Speed Volume on Radio Disabled
5.) Level Out EQ on Radio
6.) Turn Gains All The Way Down
7.) Run KEY DSP Setup at Vol. Level 15
I used to only be able to hit Vol. 15 before clipping. It'll go to Vol. 22-23 now no problem. Also I used dedicated power straight to the battery for the 200.4. Apparently if I'm not on Bi-Amp mode I'm losing out. So my question is, do I need to run new wires to the kicks from the 200.4 or is my harness good to go? Can I just tuned Bi-Amp mode ON and redo the KEY DSP?
Any clarification would be greatly appreciated. Thank you.
In order to use Bi-Amp amp, you should re-wire the front speakers so they are all on separate channels. That way the kick panel speakers can act as the larger speaker, and the dash speakers can act as the smaller speaker.
That is exactly what @AZCoyote has done. The front four speakers in the Bronco are all wired to the 200.4 in bi-amp mode, while the rear two pod speakers are still attached and powered to the factory amplifier.
That is NOT how they are wired from the factory, and that is not how they are wired on the Plug-n-Play Kits harness. With the harness, all six speakers are powered from the 200.4, and the front speakers share a channel. So if you wanted to use Bi-amp mode, you should modify the Plug-n-Play harness and set it up similarly to @AZCoyote.
Personally, I did something completely different. From the factory the front speakers are wired in parallel. I rewired them in series so speaker loads were within the 200.4's specs. I should probably try bi-amp mode, but I (eventually) intend on upgrading the rear 4" pods to larger 6.5" mods. And for that reason alone, I opted to keep the rear pods attached to the 200.4. But frankly the rear pods do basically nothing right now for the driver, so it's kind of a waste.
