Jacking Off Road - Best Practices
broadicustomworks
Hanging Rock, North Carolina
I carry a Power Built in one of my Rigs (whatever My wife is wheeling on the trip, and shortened farm jack (48in with the bar cut down to 37", so it fits inside the back with a bolt to the rollbar) in the Bronco.
Farm Jacks are dangerous tools, I seldom use one for lifting a vehicle, but the versatility for other uses in recovery is pretty undeniable. (Breaking beads on tires, short winch jobs, Lift and push to move a vehicle).
The Power Built bottle/jack stand linked several times above is by far my favorite tool for lifting a vehicle though, I store the handle, cradle, and cradle pin separately in the vehicle tool box, and secure the base/bottle with a simple l-bracket and screw knob from a hardware store.
I'd like to see your mount design. I already have some ideas, but I also tend to overbuild or over-engineer stuff too like it has to survive re-entry from orbit.
Thanks @popo_patty for the dims given on the base. Helps with planning out the eventual mount and knowing how much space it is going to take up vertically as well.
zuke
Stafford VA
You're gonna hate the way I mount stuff ;) But I'll snap a pic and post it tonight...
cynicalrider
First gen taco
I just bought the kit to make a tauler jack!
Yeah I have a kit and the jack sitting in the garage, thinking about gusseting the foot pad though.
🍿I am thinking about picking on eup for the other truck so interested in what you come up with.
MsPickles
Mi
I thought about the standard bottle jack, but I was worried about it leaking with varying altitudes, air pressure changes. So the old F250/350 screw jack it is, with some mods to make it work for stability in soils.
Ford Bronco Jacking Off Road - Best Practices s-l1600
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I sometimes have to laugh at comments about the high lift/ farm jack, I was/am a child of the 70s and growing up this is what cars had including my parent's cars, but never called by those names. They were just car jacks.
When the scissor jacks came on the scene, people would say they are crap and unsafe. :oops: :unsure:😅
Times change, knowing how to properly use things helps, but we all do sketchy sh!t sometimes.
None of this matters to this thread, just putting everything into perspective. For me it's about what works best and is portable enough.
There's no place for the high lift inside and I don't want it on the outside. I use the scissor because it's out if the way, but I hate them. That 3ton lift looks nice and the price is right, but I wish you could fold it down. A swivel base plate that folds, and the ability for it to lay on its side, as is, it takes up a decent amount of floor space. I wouldn't have a problem snapping and tightening a few pieces together before having to jack up if it means better storing options.
Mike T
Brandon SD
2023 Ford Bronco
A lot of people swear by the off-road floor jacks. I bought a badlands to see the hype. Just wasn’t impressed honestly, sure it’s a great Jack and works in a variety of terrain. But it’s just sooo heavy and expensive and takes up so. Much. Room.
I got the power built bottle Jack, it’s safe, light, jacks up really high and has built in Jack stand as well. Used that, hi-lift and badlands off-road Jack. I prefer the power built bottle Jack now. It works on my lifted bronco just fine.
https://motleyind.com/products/3-ton-all-in-one-jackstand-bottle-jack?_pos=1&_sid=a2b833725&_ss=r
How have I never seen this before! Looks like a great set up. Edited to remove dimension question
timhood
Tim
Several
The biggest dislike of the scissor jacks was how many times the screw has to be turned to lift and lower the wheel. Once I started using the DeWalt cordless impact driver to remove and reinstall lug nuts, it was an easy mental connection to use it to drive the jack. The PowerBuilt bottle jack seems like the best overall option in an off-road scenario. Of course, I think it's worth carrying this, too:
Ford Bronco Jacking Off Road - Best Practices 62611_W3
Might not even need the jack in some cases.
DriveAllNight
Dan
N.J.
Yup, you just described what I do
Draughon
Daylon
Dallas
BMW 4-Series
Nobody? Just me? Okay, I'll see myself out...
Ford Bronco Jacking Off Road - Best Practices 1715868141114-da
zuke
Stafford VA
As promised it isn't anything Pretty;
Ford Bronco Jacking Off Road - Best Practices 1715909200224-k8
Ford Bronco Jacking Off Road - Best Practices 1715909513072-q4
Whenever I'm mounting a power built jack, I just find an edge to tuck it under on one side, and then put a rivnut or stud somewhere on the other side so I can use a threaded knob to lock it down with either an L-bracket, or a straight bracket if I have to go to the floor. This particular Pic is in the back of my TJ Rubi, I have a similar setup for it in my Wife's JKU, But that's up on the lift as I'm doing major axle renovations (She managed to actually rip her Front D44 in half at the last Big Dogs event!)
I have a Farm Jack in the Bronco, I believe that they should be kept in the vehicle when ever possible, as weathering is really hard on them, and I don't want it to fail when I want it...
Ford Bronco Jacking Off Road - Best Practices 1715909742810-ja
Ford Bronco Jacking Off Road - Best Practices 1715909798693-ph
They are easily cut to any length that is practical, and by cutting a 48" down, I was able to fit it upright in the back, and run a bolt into one of the existing threaded holes in the roll bar, Doing that really minimizes the amount of space you lose in storing one, and an ARB or a Tauler would actually consume more space than this does..
cynicalrider
First gen taco
Whenever I'm mounting a power built jack, I just find an edge to tuck it under on one side, and then put a rivnut or stud somewhere on the other side so I can use a threaded knob to lock it down with either an L-bracket, or a straight bracket if I have to go to the floor, This particular Pic is in the back of my TJ Rubi, I have a similar setup for it in my Wife's JKU, But that's up on the lift as I'm doing major axle renovations (She managed to actually rip her Front D44 in half at the last Big Dogs event!)
I have a Farm Jack in the Bronco, I beleive that they should be kept in the vehicle when ever possible, as weathering is really hard on them, and I don't want it to fail when I want it...
They are easily cut to any length that is practical, and by cutting a 48" down, I was able to fit it upright in the back, and run a bolt into one of the existing threaded holes in the roll bar, Doing that really minimizes the amount of space you lose in storing one, and an ARB or a Trauler would actually consume more space than this does..
Theoretically yes but with far less ability to lift.
I believe when all said and done the Tauler jack will be only 25-28" tall with a max lift of 50+"
Also Big Dog's ftw.
Ford Bronco {thread} {filename}IMG_0505 by MJH Creations, on Flickr
This was from when I last went in 2018 after we ran Pott's and half the Shenandoah and Allegheny Overland Loop.
Ford Bronco {thread} {filename}IMG_0529 by MJH Creations, on Flickr
MNBigfoot
MN
I'm a farm kid from the same generation, we called our High-lift jack (that was general found in the rockbox on the tractor) either a "High-lift jack" or a "Farm jack". While are car jacks from the 60's and 70's had a similar design, we called those car-jacks but never a Hi-lift or a Farm jack either.
EGSquatched
Central Ohio
23 2dr Base Squatch
Does everyone have the 2 ton or 3 ton power built jack?
Any issues with fitting it under the frame with a flat tire?
