- Phil
- Jul 21, 2020
- 41
- 4,364
- 14,458
- IN
- Website
- www.ruxerparts.com
- Fords
- Badlands
Oh yeah, scroll up on this posting. I ended up using some ABS sheets and it worked great.You might get better results with plastic-dip. Hold it far enough away that you get a pebbled finish. You can do the same with rattle can paint. Essentially you're just doing a bad paint job. Cheaper. Or buy textured ABS sheets. Do a search and you'll find plenty
Can confirm they work with both. I bought both tops and it came with them on and no issues when using hard top.I’m thinking this is the trim that I posted earlier. It’s better, but still doesn’t 100% solve the issue in my opinion. It might also be too thick and interfere with the HT going back on?
@Mabett - why is the majority of aftermarket made solely for the 4 door - #2DM (2 Doors Matter)Sorry sir. Currently no plan for 2 door.
Market too small.@Mabett - why is the majority of aftermarket made solely for the 4 door - #2DM (2 Doors Matter)
I've been looking for something to cover these bolts too. Where did you get the ABS that matches the texture?It's working out great! It looks like how it should looked from the factory, and I am not constantly disgusted looking at those unsightly bolt heads
If anyone is interested in a set, just let me know.
I just got some sheets of ABS from amazon and then traced the outline with paper to create a stencil and then cut it out on my small bandsaw. I am looking to make some more, once I take off the top so that I can make another template. I've had a few folks interested in them.I've been looking for something to cover these bolts too. Where did you get the ABS that matches the texture?
Pics?I just got some sheets of ABS from amazon and then traced the outline with paper to create a stencil and then cut it out on my small bandsaw. I am looking to make some more, once I take off the top so that I can make another template. I've had a few folks interested in them.
Ah yeah, here's the link to get them...Pics?
Thanks!Ah yeah, here's the link to get them...
https://www.amazon.com/gp/product/B0BGC7NMS7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Pics?
OK, I am happy to say I have finished my C-Pillar cover and am very happy how they turned out. There’s a few imperfections, but overall it’s waaaay better!
I made a template, drew it onto the 1/16” thick ABS sheets I purchased, used my small table scroll saw to cut it out, then put on a little taste of high-grit sand paper and bingo! I used some double-sided 3M tape and stuck it to the Pillar. The color and texture is a dead-match. I think it really completes the two pillars.
Hey there, sue thing. I need to find my pattern, because my top is currently on, so that I can make them. I am pretty sure they are in my garage some place Let me check and see what I can do.I’m interested!!!
