Is there a powered USB (all the time)?
straycatboat
rick
bronco 2023
I have a 2023 base SAS and the USB under the radio is only powered when the vehicle is on.
I am looking for one that is powered all the time for my phone holder/charger.
userdude
Denton, TX
2023 2dr Badsquatch
I use the aux power that's in the back of the console with a car charger. I assume every model has this, but maybe not. There's even a little passthrough notch to allow the cable to go through.
MNBigfoot
MN
None of them stay on for more than an hour or two(?), however using forescan that can be changed to 24 hours (?).
straycatboat
rick
bronco 2023
Is there anyone with a Forscan that lives close to Sebatian , Fl that can help me reprogram some .?
Baysquatch
Cash
SC
This one is powered all the time and cheaper and easier than forscan
Ford Bronco Is there a powered USB (all the time)? IMG_5821
T
HoosierDaddy
__ Eric
NW. Indiana
Without even searching to verify, I'm 100% certain there have been installs of constant on and propely powred USB/USB-C ports.
(the factory usb ports are weak, even the C version is powered less than what the minimum standard calls for. Actually, it shares the weak power supply with the standard USB port, ..... according to what I've read.)
straycatboat
rick
bronco 2023
Where did you get this?
It could work
Baysquatch
Cash
SC
It could work
Ordered it from Amazon. Punched through the firewall grommet and wired directly to the battery
contrary to combustion kings thoughts, it is neither bulky nor unsightly
A little bigger than a pack of cigarettes and isn’t really noticeable
Ford Bronco Is there a powered USB (all the time)? IMG_5825
Ford Bronco Is there a powered USB (all the time)? IMG_5823
