Inverter recommendations
ontheheel
Oceanside, CA
2023 Bronco Badlands
What works well and lasts a long time?
Feel like Redarc 1500w is the best option, but it’s also 2-3x the price of the competition. Reviews on other devices have me scared about reliability.
Need to power a 1200w induction cooktop.
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
I have had the Xantrex freedom xc 2000 on my off road trailer for ~5 years and never had an issue.
Honestly, I'd go with a battery generator / portable power station these days. Like the Bluetti / EcoFlow / Jackery. / Goal Zero
They are a bit larger in size, but a lot easier to work with and more versatile. You can trickle charge them back up while you are driving with a simple 12V adapter, and then run them safely with the Bronco turned off. And optional solar or alternator connections to charge either faster or without using any fuel. And you can pull them out of the Bronco and pop them anywhere like a regular generator to use them wherever. Very handy.
The Bluetti 1500W version is on sale right now for half the price of the RedArc inverter - so it won't cost you more than what you are already looking at. Just takes a bit more room up in the back. You pay more for runtime than you do wattage. This one would run your hot plate for about an hour before it would need recharged -- longer if you have it charging while used (from any of the various sources)
https://www.amazon.com/BLUETTI-Portable-AC180-Generator-Off-grid/dp/B0C1SMJTDT
ontheheel
ontheheel
Oceanside, CA
I had an ecoflow delta 2, which was fine, but insufficient. DC charging is painfully slow (and liable to burn Bronco fuses - ask me how I know). Biggest problem is the giant block that occupies a tremendous amount of space.
I’ve got a flat 100Ah battery mounted to my back seat and charger, bus bars, and fuses on an AAL rear window MOLLE panel. Inverter will go on the opposite window.
My new setup takes up zero space that I would otherwise use, offers more flexibility, and charges at 40A…blazing fast.
Only decision I have at this point is just what kind of inverter to get.
This kind of changes things - I think we were all assuming you were doing a plain 12vdc from the AGM starter battery.
What voltage is your battery bank running at?
ontheheel
ontheheel
Oceanside, CA
12v DC nominal (13.8)
I’ve had decent luck with Renogy like @High Velocity, and Outback.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
1200 w load would pull at least 100 amps off the DC
Get a little generator
ontheheel
ontheheel
Oceanside, CA
indeed it will. Battery is rated for 120A continuous and 200A peak. Not interested in a generator. Interested in an inverter.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
2 Awg from battery to inverter. Make sure inverter has adequate cooling. Also use quality fuses/ blocks and lugs. Good luck.
Will be cool ...or hot in your case. I would try it out with temp cables and your load before installation. That would prove your inverter an battery system in the Bronco will handle it.
I have built many DC systems.
Paul in AZ
ontheheel
ontheheel
Oceanside, CA
Thank you. Ended up buying the Redarc. Redarc specifies 3/0 wire for the roughly seven feet up from the bus bar over to the inverter on the other side of the cargo area. Putting a maxi fuse in line. Photos below of where it stands right now. Will need to finish running the wires to it and cleaning up the charger/distribution side. Wanting to replace my fuse block with a fused Anderson distribution block soon to help simplify and clean things up a bit. Inverter will remain tied to the bus bars.
Ford Bronco Inverter recommendations IMG_0191
Ford Bronco Inverter recommendations IMG_0192
Ford Bronco Inverter recommendations IMG_0194
TLO
Canada
youtube.com
2 door
Can I ask what battery setup you plan on using for this? 1200w (if you actually pull that much) will be about a 90A draw at he battery. Maybe would be a le to pull this off with a 100Ah sized battery... Or 2X or 3X 50Ah
ontheheel
ontheheel
Oceanside, CA
DCS Slimline. Rated for 120A continuous.
  • Like
Reactions: TLO
akturbo
Seattle Eastside
That DCS Slimline looks legit mounted on the back of the seat. Do you have any more pics of the battery install? I was planning to do the 4x20ah batteries in the storage tray for this summer, but this looks like a great option.
