Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
2.3L Bronco Closed Box Intake From Volant Performance with 3 Filter Options!
Ford Bronco Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼 170026_a_lowres_2000x
Volant's cold air intake unlocks added performance from the Ford Bronco 2.3L EcoBoost engine along with added protection giving you confidence that your vehicle is not only getting the added benefit of an aftermarket intake, but also that it is protected from the harshest environments while exploring the world around you. Volant's Ford Bronco cold air intake with free-flowing DryTech synthetic filtration is perfect for maximizing your performance gains while minimizing your maintenance concerns for on-road daily driving. Each intake comes with a pre-filter protective cover that adds hydrophobicity to your filter for added protection, but still allows uninhibited air flow. On top of keeping your filter dry, it will also keep your filter free from mud, sand, or any other debris resulting in greater filter longevity.
Filter Options
Ford Bronco Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼 170026_c_lowres_2000x
PowerCore Filter
Not all filters are created equally, as they are purposefully designed to cater to the environment they will be used in. If you plan on taking your Bronco Offroad, then this is the filter choice for you as the PowerCore provides maximum filtration by filtering out microscopic debris that filters can't. These filters also provide 100,000 Maintenance Free Miles!
Perfect for the Frequent Offroader
Drytech Dry Filter
The Drytech DryFilter is the perfect filter who are after a filter that provides the performance gains of a traditional cotton gauze media with the simple maintenance of a non-oiled filter. This filter offers up to 50,000, after that maintenance is as simple as can be using just soap and water! No oiling required!
Perfect for the Daily Driver
MaxFlow 5 Oiled Filter
The MaxFlow 5 Oiled Filter is designed for those looking to get the most performance possible from their filter! The trade off with the added performance is the required maintenance of this filter as it does require regular cleanings and reapplication of filter oil.
Perfect for those seeking Maximum Performance
The Volant Performance is not only a great addition performance wise, but it also looks great in the engine bay! If you are looking to pick up a Volant Performance Intake, you can do so using the link HERE!
Ford Bronco Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼 17002_b_lowres_2000x
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Do these intakes have a drain for any water that ends up within the box?
Not that I’m going to scuba, but I’ve found that the bronco loves to ingest snow throughout the winter, which has a tendency melt, aerate and inevitably freeze up the throttle body… ask me how I know… Luckily it will melt down, and drain out the factory box, at the expense of it being a “sealed” design
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
Any copies of dyno readouts with proof of "performance gains" from any of these intakes? I bet we get crickets. Jim.
Caleb@PandaMotorworks
Caleb
St Louis MO
This is on the 2.7L. Looks like 11hp gain on the oiled setup, 12hp on the dry
Ford Bronco Introducing Volant Performance Intakes, Available at Panda Motorworks! 🐼 volant-ford-bronco-2-7l-closed-box-air-intake-2021-ford-bronco-2-7l-stickerfab-4_4000x@2x.pro
userdude
Denton, TX
2023 2dr Badsquatch
+1 for the Donaldson's PowerCore. Two things, though: Gotta blow it out occasionally, and getting the pre-filter on is... not easy. Installing the filter at all is a little dicey, since it has a rubber collar that has to be wrapped around the intake (somehow) and it's just a little too long to fit... lol But then taking the prefilter on and off, yeah, have fun with that. It is nice and if it lasts anywhere close to 100k I'd buy another.
CarmeloS
Carmelo
Central Jersey
‘21 2dr Bronco
Love mine, and that it’s just soap and water
am curious about the water drainage though, I dont wanna go fording water with mine
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
Filter Options
PowerCore Filter
Drytech Dry Filter
any plans for the 2.7L Bronco ?
fourdayoff
Boulder City Nv
Caleb, Thank you. First results I've seen. Any plans for the 2.7?
Boreal
Colby
MB
2022 Badlands 2DR
Mitch
St. Louis, MO
Mitch
St. Louis, MO
How I know… Luckily it will melt down, and drain out the factory box, at the expense of it being a “sealed” design
am curious about the water drainage though, I don't wanna go fording water with mine
I cannot confirm or deny if there is a provision for a drain hole as I have yet to check one out first hand yet unfortunately.
