chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Anyone know what to do with this error message??
It looks like you might have changed the settings under the hood without the APP open.
Once you change the drive modes with the APP it should reconnect and leave manual Mode!
Than you
BroncoNS22
Nick
2022 Ford Maverick
I just placed my order on Friday and canā€™t wait to install! It will be interesting to see the difference from the base setting #1 through #7. What seems to be even more impressive than peak numbers is the hp and torque gains low in the rpm range. I spend most of my time under 3k rpmā€™s and those torque numbers on the dyno sheet blow away any other mods when youā€™re talking hp and torque gains per dollar.
For anyone willing and able to spend $400+ on a CAI or exhaust set up knowing there will be minimal gains, this should be a no-brainer to see a HUGE increase in power.
scotman623
Saratoga Springs NY
Chevy LT Trail boss
This Weekend!!
10% OFF the Panda Power Module!
Use code "FF10" at checkout
Feel free to message me with any questions!
Ford Bronco The Panda Power Module is HERE! The First 2.3L Tuning Solution by Panda Motorworks! Power Module Flash Sale
Old thread, but do you have any codes or discounts for this product now? I believe I decided to buy this over the JB4.. Thanks, Scott..
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
is this just a pedal booster - like pedal Monster or actual tunes?
Caleb@PandaMotorworks
Caleb
St Louis MO
This plug-n-play module checks the OEM sensor data and configures the signal safely and reports back to the sensor. In turn, this is how we are increasing the power and torque of your Bronco
The pedal commander, or whatever its called, only changes the sensitivity of your throttle. It does not provide any performance gains.
You can learn more by watching these videos!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Have you testing using this in conjunction with the Ford Performance tune?
St. Louis
We have not but other customers have and seem to enjoy it. I am not sure what the logs etc look like but no one has reported any issues.
Thank you
redone17
Cold Spring, NY
Thank you
Yeah, Iā€™m curious. Would love to see more documented info.
redone17
Cold Spring, NY
Thank you
Any indication on what your module does differently than the FP time? Would it be sort of a multiplier or is it performing differently and youā€™d consider it complimentary?
