Instructions on capable bumper removal and replace with modular?
Lak34ers
Troy
Seattle
Trying to find You Tube to remove plastic bumper, cant find. Help !
I know the capable bumper is not worth much but I'm looking to buy the hooks if anyone will sell me just the hooks.
Kuljit530
Kuljit
Ford Bronco
Bumper on, all sensors work, used floor jack to lift and a little help from my wife. I’ll post pics in a bit.
The sensors worked just fine? So basically just cut off thr hooks rewire the sensors and its good to go?
Jeffz95
Jeffz95
Kiowa, CO
Nissan NV 4x4 van, 78 911, 08 Jeep Rubicon
Cut off hooks ? i pulled harness off old bumper and put on new. the little tabs dont all line up on mod bumper so I just trimmed off with razor knife the ones that dont align.
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
I did this last weekend. The capable bumper wiring harness is a little tight on the modular bumper but it fits. Pop the plastic off around the tow hooks, remove the three bolts on each hook and the bumper comes right off. No way it’s an 8 hour deal….
I kept the capable hooks on the modular bumper. I like them better.
Ford Bronco Instructions on capable bumper removal and replace with modular? 210927DC-AF9D-42C9-A35B-731D422AA3AD
BroncoBarn
Illinois
2002 Wrangler
Can the Modular hooks go on with the capable bumper?
Dmorty217
Derek
Venice FL
Camery
I’m sure it’s been answered but pop the plastic covers off and there will be 3 bolts on each side, remove them and the bumper comes off.
iBrad81
Brad
Cleveland
2024 Ford Ranger Raptor
When you bought the mod bumper did you have to buy any other brackets, bolts or anything or does the capable and mod bumper share same brackets etc. i have a BL with capable and may want to add the mod bumper later
Flourman
Centennial, CO
I bought the mod bumper used off another person who upgraded to a aftermarket bumper. That particular aftermarket bumper didn’t use any factory brackets so I got everything I needed. But these bumpers literally use three bolts at the end of each frame rail to bolt them on. Pretty simple.
PrevCYBRTRKrez
Jacob
Decherd, TN
2023 4dr Badlands, 2020 Lincoln Aviator
CaptainRob
Las Vegas
22' Bronco
Fyi, if upgrading from a base plastic bumper to a modular and you don't have the steel skid plate to go along with it you'll have to cut up your plastic a good amount to get it to fit with the modular. All the cutting is at the top side where it really can't be seen behind the bottom of the modular bumper.
I cut off the tow rings on my brackets and it was a direct swap otherwise. I also did not have sensors to swap, but the modular bumper had holes for parking sensors so I filled them with rubber grommets.
Here's a Pic of the horseshoes I made.
Ford Bronco Instructions on capable bumper removal and replace with modular? 20220916_145126
Clint Callahan
Clint
Tennessee
2013 Toyota Tundra Rock Warrior Edition
I know this is a dust covered post now, but I’ve been in the hunt for two months and finally found one. Came back to this forum that I had saved to see the comment about a torx plus 45 and had to ask what the difference between that and a normal 45 are. Before I got to get it this weekend I’d like to make sure I can avoid a very frustrating Sunday by having the “plus” if I absolutely have to have it. Would a regular t45 seriously not work? Can’t find the plus anywhere in town and Amazon doesn’t even look like it would be here this weekend. Thanks all
Jeffz95
Jeffz95
Kiowa, CO
Did you check your Bronco tool kit ? I ordered a set through a auto parts store and was there the next A.M.
