Installing TeocaliMG's front differential drop kit
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
Installed @TeocaliMG 's front diff drop today. I had pre cut the front diff skid beforehand, using Teo's template from another thread.
Cut the front skid plate left rear bracket off, since the drop bracket doesnt have a threaded hole, notched the side of it, and used an unused tapped hole in the frame to secure the front skid plate. I was in a bit of a rush finishing the cuts. I may clean them up later.
Rattle canned that sucker Badlands orange to match.
This kit is installed on my Badlands non Squatch. I have 1.5" spacer lift installed, making the total front shock length 24.5", which is about the same as some aftermarket shock options. I want to keep the axles/cv's in a less drastic operating range.
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_141540
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_141546
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_141022_HDR
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_141033_HDR
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_162514_HDR
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_151140
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_151144
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_151319_HDR
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_151331_HDR
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_162612_HDR
Post diff drop,.quick road test to settle suspension, ride height.
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_163713
Ford Bronco Installing TeocaliMG's front differential drop kit 20240419_163737
Oldhippie
Barry
Santa Cruz, Calif.
Very kool! I just got the same kit today… will get it installed along with Hoss 3 rack…maybe next week….any clues on install?
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
The OEM front mount bracket has an extra piece of metal bent over the differential mount bushing. Just need to drop the diff enough to pull the bracket out. The right side spacer is simple enough. The rear mount was fun. There are two bolts securing the rear mount to the differential. The right side bolt hole uses a dowel pin for centering, hence the larger hole on the right side of the provided spacer. I lowered the diff and pushed it forward until I could get the spacer inbetween the mount and diff. Used a heel bar to help center the mount, spacer, and diff to run the new bolts in. Loosely installed all fasteners, then gave em some ugga duggas with my 1/2" air gun.
TeocaliMG
Plymouth Michigan
2021 Bronco Badlands non-sas 4 door manual
Looks awesome!
If you really wanted to be anal about it, you could probably grind or shim that passenger side spacer to get the angles exactly symmetrical. I'm sure theres some vehicle-to-vehicle variability. (Could also be variability measurement to measurement)
Love the Orange! Dont hesitate to reach out if you have questions regarding install (other folks).
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
Looks awesome!
Thanks! The difference could also be from that angle gauge. It's sensitive, haha.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
Hey @Sitruc_btb on your Badlands non-sas you still have stock 33” tires, OEM Bilsteins and have added just the 1.5” lift?
CV angles look great. What is the angle measuring device?
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
I changed the tires to 315.70r17 Firestones. Same size as the Squatch Goodyears. Yep OEM Badlands special Bilsteins, with a 1.5" top hat spacer.
Measuring device is a Cornwell tools magnetic angle gauge.
murphtron
T
Berkeley, CA
Cool. So is it about 2.25” lift over stock (I’m assuming about .75” lift from the tires) ?
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
Yeah I guess so, according to the math. Doesnt sit much higher than a Sasquatch Bronco. It's not jacked up real high by any means, just a bit taller.
murphtron
T
Berkeley, CA
If I remember correctly Squatch Badlands only has 1/2” greater clearance than non-squatch. Don’t recall the reasons why. That’s one reason why I didn’t go Squatch.
Classic28
Brandon
Maryland
Nissan Titan
Does anyone have a link to buy?
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
Correct, Badlands vs Squatch height is a 0.47" difference. Squatch is higher to clear the 315's. Stiffer spring rate or what, not sure.
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
Dusty
Mentone, CA
70, 71 & '21 Broncos
I installed my Broken Innovation diff drop yesterday, after swapping in a new set of Ford Performance CV axles. The installation was fairly straightforward, but yeah those rear mount bolts were a party. Kudos to @TeocaliMG on a great product.
