Installed Mabett back seat/cargo area ceiling light
steezyB6G
Ryan
OCsocal
2012 Toyota Tundra long travel prerunner
i've had mine for a couple weeks now. Finally going to install it this weekend.
buzpro
Binky
Tacoma
Installed mine tonight (3/3/23) .... I am not overwhelmed by the amount of light it puts out ..... its better than what Ford put out but nowhere near what i expected .... I expected more out of 3 LED strips!
Sunday Money
Thanks for the review. Just received an update that my 2/25 order should be delivered tomorrow. I may hold off on installing until there's more feedback from this latest round.
Mpali
Illinois
2022 Wildtrak
Where did you purchase this light. Amazon is constantly out of this item.
buzpro
Binky
Tacoma
Amazon .... i clicked on the link on and it said out of stock, then I clicked on the part and it said in stock
Sunday Money
Installed the Mabbett back seat/cargo area light yesterday. My photos make it look brighter than it actually is, but it's MUCH better than the factory light.
IAG probably a better all around lighting solution but not a 5-minute plug & play install.
Ford Bronco Installed Mabett back seat/cargo area ceiling light IMG-5655 (1)
Ford Bronco Installed Mabett back seat/cargo area ceiling light IMG-5654 (1)
Jersey250
Allen
2022 Ford Bronco base Sasquatch
I have the Mabett rear cargo light, solid piece, great fit, easy install, good lighting. I also have there foot well lighting kit also a solid thumbs up. easy install panels fit great. I have all this coupled with the IAG interior light kit, all great products. That interior is so bright now I can see the future.
Levinds
NY
2023 Bronco
Was a relatively simple install. Lighting is much better than what came from factory. I am pleased with the upgrade.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I installed mine today and ran into a couple problems. @Mabett can you help?
1.) Wire harness connector doesn’t clip in. It pushes in pretty snug, but doesn’t “click” like the OEM one.
2.) Mine is very loose. It’s only held in by the two metal clips. The provided sticky tape isn’t thick enough to adhere to the roll bar trim. It looks fine, but as soon as you touch it it’s pretty loose and will likely rattle off-road. I’m afraid if I pull it back down to add my own thicker sticky tape, it will likely break or bend the clips just like when removing the OEM light.
Anyone else with these issues and how did you resolve? Thank you.
da_jokker
Jeep Wrangler JKUR
I didn't have any problems with the plug clicking, but I had posted about how they're sticky tape is too thin and doesn't even touch the trim.
They're light popped back out much easier than the factory light (aka I was able to do it without bending anything) So I added three strips of double back foam tape and then put it back in and now it's a snug as could be.
And I use rubbing alcohol to clean the surface both times.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Thanks for the tips. Pulling it back down and adding some more sticky tape seems easy enough. I wonder why my connector doesn’t clip in. I spent a decent amount of time trying to get it to clip in and compared the OEM connector to the Mabett connector and didn’t see any differences. Guess I’ll have to investigate again when I pull it back down to add more tape.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
For those interested with similar issues, I fixed my problems. I pulled down the Mabett light (which in my opinion was just as difficult as Removing the OEM light). I added 4 thicker and wider strips of double-sided 3M tape. I also gave it hell to get my wire harness connector seated / “clicked” in all the way. I found my Mabett wire connector had just a tad too much plastic so had to really leverage it in with a screw driver as opposed to just a push & click. But finally got it to click in. Then I pushed it back up in the hole and it secured in very nicely now with the clips and 3M tape. Very secure now and I can finally say I’m happy with it. Just a bit more QC with Mabett on this one and it would have been flawless and saved me a boatload of time.
bradcd
Brad
Saab 9-3
My install completely echoes this. Too much plastic around the Mabett plug to connect cleanly. Installed the light as it was just to see if it'd work and it remained loose in the ceiling plastic with some gaps. I pulled it back out, relocated the gray adhesive strips to outside the indentions, and then stuck on three cut strips of thicker double sided tape in the indentions. I used whatever double sided foam tape I had lying around. After all that it seems to hold and I don't think I hear any rattles...
Ford Bronco Installed Mabett back seat/cargo area ceiling light IMG_20230318_134726-2
Ford Bronco Installed Mabett back seat/cargo area ceiling light IMG_20230318_135551-2
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
My install completely echoes this. Too much plastic around the Mabett plug to connect cleanly. Installed the light as it was just to see if it'd work and it remained loose in the ceiling plastic with some gaps. I pulled it back out, relocated the gray adhesive strips to outside the indentions, and then stuck on three thicker double sided tape in the indentions. I used whatever double sided foam tape I had lying around. After all that it seems to hold and I don't think I hear any rattles...
Thanks for the tips! Mine finally arrived and I hope to install this weekend.
Bender031
Pennsylvania
2021 Bronco Badlands Sasquatch
@Mabett I am having the same issue as mentioned above, I cannot get the connector to click into place no matter how hard I try and what angle/coaxing. Do you have any suggestions? Otherwise I may initiate return through Amazon. Looks like you've been very responsive and supportive through here so I thought i'd see what your thoughts were prior to going through amazon. Thanks
