Installed chase lights using SFR brackets
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
After a romp through the desert and a recent night run, I realized the importance of chase lights.
Bolted up a pair of SFR brackets to the spare tire carrier, and used Colight Rob2 Pros. Small(ish), low current draw, reasonably priced. Tight fit under the light brackets, but they work. Wired to Aux 6 using Ford's pre ran wires to glove box and cargo area.
Ford Bronco Installed chase lights using SFR brackets 1000012219
Ford Bronco Installed chase lights using SFR brackets 1000012222
Ford Bronco Installed chase lights using SFR brackets 1000012248
Ford Bronco Installed chase lights using SFR brackets 1000012243
Ford Bronco Installed chase lights using SFR brackets 1000012244
Ford Bronco Installed chase lights using SFR brackets 1000012249
Nahdud829
Robert
Orange County, CA
2013 Yamaha R6, 2015 Honda Civic
Thinking about going this route. How has the stinky fab bracket held up after a year? I spend a lot of time in the mountains and desert.
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
Brackets, and lights, are doing just fine. Haven't used them as much as Id like to, but the fit and finish are great. For what it's worth, they're exposed to the AZ sun day in and day out, no excess wear and tear so far. I'd recommend them for mounting up some lights.
Nahdud829
Robert
Orange County, CA
Perfect. I know first hand how much damage that AZ sun can do. Do you think they'd support the weight of the new Diode Dynamics SS10 Chase light? My plan is to use the new chase light to replace the OEM 3rd brake light.
Sitruc_btb
Sitruc_btb
Curtis
Chandler, AZ
I'm sure they can support the weight. DD says it's 3lbs? Shouldn't be an issue, especially spread across the both of the mounts. They are sturdy and are well secured to the spare carrier. They may flex a tiny bit when closing the tailgate since they are top heavy with lights, but nothing to worry about.
