INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too)
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Now I’m thinking about using this spot if I cut and splice. I’ve already broken the zip tie that used to be part of that plug. Just got to get the right goo to seal it up. And I think it’s accessible without taking the taillight off.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 9E317474-D7A6-49C8-9A78-AAA0EC2B715C
swooshdave
Portland, Oregon
Mustang
There’s nothing preventing you from alternative plans. From their standpoint they wanted to avoid drilling or hooping on silicone to seal a hole.
kodiakisland
Arkansas
I was thinking about getting these, and from watching the video I couldn't understand why all the wiring couldn't run alongside the current wiring in the tailgate, and why the need to go under the truck and up through the storage area...
It's to have the reverse light function. Mine are wired to the aux switch and all the wiring is inside the vehicle behind the interior panel and through the tailgate. I went with amber spots for true chase lights and have other lights for reverse lights.
My reverse lights wiring that are tied in to the tail light harness stays completely within the bumper.
mikec426
Russellville, AR
I ended up going through the smaller hole and cutting and splicing the wires. I’ll get some stuff to seal it up tomorrow.
BaseManSquatch
United States
What is the process of uninstalling the lights if you want to change your tire?
I'm thinking of getting two sets of tires. One for daily commute and one set for offroading. How long does it take to uninstall and reinstall the spare tire?
Dadsquatch
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
It’s just two more bolts than normal & a quick unplug of each light. Probably adds another 3 min to removing the spare. The two additional bolts are the same size as the lug nuts, so no additional tools from normal are needed.
swooshdave
Portland, Oregon
Mustang
Well done. You had all the same problems I had, lol. More struggles ahead when you go to connect the AUX wire, but I feel like that's such a good feature to use if you plan to use them as chase lights. BUT......if you ever just want to turn on the white lights without being in reverse, then your rear zone lights will turn them on too (pretty neat). However, you can't turn zone lighting on unless you're in Park, which is normally fine, but again not necessary to have them on while driving unless you plan to use them for chase lights as I've already mentioned.
I finally got around to wiring up the Aux Switch (#6 in case you were wondering).
Im not showing the rear wiring. It went pretty easy. Just pull the side panel back at the top until you can drop the aux pigtail back behind it. As has been mentioned many times actually connecting to the aux wire is a pain. I normally don’t like crimp but connectors but unless I removed the entire side panel I didn’t have much choice. And yes you cringe every time you pop a panel off.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 4E0908BD-D5DB-4677-8C01-391427A860A2
Now to the front and the glovebox. Take the entire glovebox off. Once you release the stay on the right side the glovebox drops all the way down and comes off super easy.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 210A600D-DE6C-48F8-BA8B-91EF6517A8A6
Do you see the white/orange wire coming from the back? Neither could I. I ended up taking off the speaker panel (which you shouldn’t have to do) and kept looking around. The other problem is that the early wiring notes have it as white/grey. I finally found it tucked way high on the far right. The trick is the wires are taped to the main harness. I do the tape to give you more play.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 432E2163-DC70-41AE-A524-7F240696422A
The other wires were easier to find. Remember there are four wire ends down here. White/orange from the back. Grey/orange runs down from the visor. Then you have two jumper wires that run from the glovebox to the engine compartment. It doesn’t matter which of these jumpers you use, just don’t forget when you get under the hood. I chose the white one. The other is brown/white.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) AA47F10E-6AAF-4904-9A49-2D1B25ED57CE
So just white to white/orange. And then put back all the panels you removed to find the dang wires.
Back under the hood it was a simple white to which ever switch wire you want to use. Since the lights are at the back of the rig I went with switch 6. For me it was yellow/orange.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 70AE6E89-4525-4CEA-9C25-E6B6F9C96AA4
That was it. Now I can flip on the white lights at any time.
Dadsquatch
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Excellent job! It’s all worth it in the end.
los7883
TX
Chevy Corvette
I ended up tapping the reverse light wire on the inside of the cargo area and was able to bypass all the external wire routing. From here I just ran it right alongside the existing wire loom and through the tailgate.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) AC8366DA-E276-49C4-A2CA-ED88FB627B81
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 328D413D-5153-4EF4-9A3F-78B305180143
Dadsquatch
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Nice idea!
Andrew
New York
2022 Bronco Black Diamond
Did you just cut off their harness that goes inline with the factory plugs?
los7883
TX
Chevy Corvette
They don’t have a harness for a 6 inch light bar from DD so I ran my own wiring to the light. The light bar came with a pigtail so I connected my wiring to that.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 9CF9D149-6C36-4F91-8B99-50880CEDEF70
Axle Roads
Northern California (Gold Country)
2022 Bronco Badlands 2 Door, 2017 Nissan Frontier
I didn’t want to run the wires outside the vehicle either, so I looked around and found that if I lift up the rubber going between the tail light area and the cab I could push the small end of the harness through and avoid the external routing.
Ford Bronco INSTALLED Diode Dynamics Reverse Light Kit (Chase Lights Too) 3C3D9653-4749-43C6-A348-C421FB40F88D
los7883
TX
Chevy Corvette
Yup looks a lot cleaner!
Axle Roads
Nice looking wiring job, looks like you’ve done that a few times.
