- Eric
- Jul 22, 2020
- 14
- 1,415
- 3,958
- Fidalgo Island, WA
- 23, 69 Bronco
- Base
For whatever reason, the price of the 4-door and 2-door skid plate sets are the same, despite the 4-door set including a massive fuel tank skid plate that the 2-door set does not because they already have tank skids. So, I bought the 4-door set from our very helpful forum sponsor @flip (Phil) using the B6G discount and had it sent to the local freight terminal. I have the fuel tank skid plate for sale here so feel free to make an offer.
https://www.ruxerparts.com/oem-parts/ford-kit-skid-plate-mb3z5d032e
I don't think they're available but the part numbers on the individual plates are:
MB3C-5R108-BC bumper skid
MB3C-5B018-AB engine/rack skid
MB3C-7E063-A transfer case skid
Looking at pictures on Levittown's site, the 4-door "engine" skid plate, which is really protecting the steering rack, has some extra metal surrounding the rearward holes but I'm not sure why. No matter, it bolts up fine. All 3 plates are simple enough but I did have to cut the tow hooks off for front plate clearance. I'll have to find another front recovery point solution until I get around to building a bumper.
The 4 plates are 150 pounds when palletized. The 3 I used aren't too heavy but they seem thick enough to do the job unless you're more of a rock bouncer than a rock crawler. I used the bolts from the kit but they're the same as the ones I took out. The transfer case skid required the 4 bolts and 2 nut clips included with the kit.
I did throw a couple coats of paint on those cut ends to keep them pretty. You can buy the brackets without the tow hooks but they were about $100 each, as I recall.
The metal skid doesn't come as far forward as the plastic one did so there is some gap fore-aft, though you don't see it from a normal vantage point.
There's about 2" gap between the frame and the plate if you want to attach a recovery point to the bottom of the frame.
This area is still exposed, though nothing critical is hanging too low. Ford does sell a skid plate that covers the front part of this area to protect the sta-bar disconnect but I'm hoping somebody comes out with a higher clearance transmission crossmember and skid plate. Ford could've done a much better job tucking that part up.
