1st7MT
LI NY
Has anyone with rear remote resivors figured out a mounting solution for aftermarket frame mounted rock sliders? I've got a set of White Knuckle sliders that can't be installed due to the resivors location.
djscoutmaster
I am a Gen 1 Raptor owner with the icon Stage 3 on it. When I switched from stock fox shock to icon, it DRASTICALLY stiffened the ride on the street. Don't get me wrong, it was a BEAST OFFROAD compared to the stock suspension, but it destroyed daily driving. The stage 8 kit with the electronic shock has me very interested in a new Bronco Wild track, but im hoping someone can answer a few questions.
1. Is the Icon Stage 8 kit for the Bronco stiffer as a daily driver than the stock Wildtrack setup?
2. How would you compare the offroad performance of the Icon Stage 8 kit to the Bronco Raptor?
TruckCamper
Peter
Kingman AZ
2023 Bronco 2Dr - 2022 Bronco Raptor
We the Icon CDEV on our 2dr Bronco. It is much "firmer" on road (lowest setting) compared to our Bronco Raptor (which is rather plush). Have the same wheels/tires on both rigs.
I will say... the Icon Shock "Calibration" has never worked on the app. My understanding is without completing the calibration the dynamic adjustments don't work. Icon support wasn't able to resolve. That has been disappointing as the point of the electronic is somewhat lost. We've had them installed for about a year so probably out of luck on getting fixed.
Can't beat the Factory Fox for ride quality and good off road ability. I'd absolutely buy the Raptor unless you want the 2dr... We have both and love them! 2dr Manual is a MUST (it is absolutely fantastic - one of the most fun manuals you'll drive).
Aeromech2284
2013 F150 FX4
Did you end up finding a solution? I've got the stage 4 kit ordered and the white knuckle sliders are at the top of my list.
Aeromech2284
2013 F150 FX4
Has anyone who installed these ICON kits needed to install longer rear brake lines? I installed the stage 4 kit this weekend and at full rear sag I feel like the brake lines are a bit too tight.
Charles Miller
Charles
San Jose, Ca
Soon Bronco 2021
Your Icon Ford Bronco, could you tell me either the amount of preload your running (amount of threats on the front shocks) or the height measure from the front frame to the ground?
Thank you,
Charles Miller
Bay Area Broncos
QUOTE="Dusty at ICON, post: 1235523, member: 26872"]
So far the only real-world fitment experience we have is on our own Bronco, the one in the photos at the beginning of this thread. It has our 0" offset wheels with 37" Nitto Trail Grapplers. So, we know from experience that that specific combination fits just fine. We have also tested with the other wheel and tire combination I mentioned (35's with +25mm offset wheels) and stock Sasquatch wheels and tires. Any other tire and wheel combination you will have to determine for yourself, until we can get more data. But note that the 0 offset we recommend for 37's is due in part to clearance for the UCA, not just tire fitment in the wheel well.
[/QUOTE]
Ksomos
Kevin
Buffalo, NY
Just received a set of icon coil overs that springs have paint missing. Should this be cause for concern?
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) IMG_2822
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) IMG_2819
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
Yes, the concern is that they should not have been sent to you in that condition. Please contact ICON customer service and they will replace them.
