- First Name
- Dusty
- Joined
- Oct 4, 2021
- Threads
- 18
- Messages
- 404
- Reaction score
- 1,329
- Location
- Riverside, CA
- Vehicle(s)
- 2021 Bronco Base 2-Door
- Your Bronco Model
- Base
- Thread starter
- #61
Yes they are designed to level the vehicle along with the stated lift. Keep in mind though, that some equipment configurations and gear load-outs can make it sit un-level. For example a heavy front bumper and winch, or a 37" spare tire at the other end, or a rooftop tent, etc. But the coilovers have a threaded body so you can make small adjustments at either end, if you need to.Do these packages level the vehicle?
Ive got a Sasquatch and want to run 37’s with the stage 3, do I have to adjust the coil overs, or just plug and play?
I do need to mention the 2-door, though. Since these kits aren't specific to 2-door or 4-door, the lighter weight of the 2-door means that it will sit slightly higher than the 4-door, and it will also get a slight forward rake (slightly higher in the rear).
