How important is the stabilizer bar disconnect?
FTBronco9
F-150
Ok, so I’m pretty much new to the idea of off roading/rock crawling/trail riding. The only limited experience I’ve had has been in the sand/desert. Now, with that being said. How important will the stabar disco be? I plan to still go to the desert but also want to go on trails and do mild rock crawling. Nothing that’s going to damage or hopefully not damage my $60k Bronco. All the videos we’ve seen of the Broncos being tested in Moab and even as recently as the qualifier run at KoH; would all that require the stabar disco? I’m currently ordering a WT, so will I be able to add this aftermarket if necessary? Thanks in advance for the answers.
Philly
Dallas, TX
2022 JL Rubicon
The hydraulic disconnect will be very nice to have, but it shouldn't be too difficult to do manually. If you are going to manually disconnect, you're going to want to do it on flat ground prior to entering the trail, and you probably won't be able to reconnect until you are back on flat ground.
@indio22 brings up a good point about not knowing how IFS will handle in all situations, but I would say if you are under 20mph (the point where the sway bar would reengage) for the type of driving you are doing, then go ahead and disconnect at the trailhead. If you are planning on going fast for the entire trail or you're doing some desert running, I wouldn't worry about it.
You don't HAVE to disconnect ever, but it makes things much more comfortable on even mild trails. Do it once in a Jeep and you will know exactly what I mean. It won't be an exact comparison because the Bronco is IFS, but it will give you an idea of the difference.
Silver-Bolt
Eureka, MT
It's not important at all. It can be done with simple hand tools in less than 5 minutes. On the Raptor many have ditched the sway bar altogether.
Toccoa
Isuzu Rodeo Sport
Ford Bronco How important is the stabilizer bar disconnect? 1612993868916
Ford Bronco How important is the stabilizer bar disconnect? 1612993917461
How else are you gonna park? 😁
Benzo
Ben
Bay Area CA
too many to list
From an old post when we first reserved our broncos. Search for "Stabilizer Bar Disconnect in Action". You can always save the $ and do it manually but as others noted, do it at the start of the trail.
Sampsonrustic
Sampson
SoCal
F150 4x4
totally irrelevant for 95% of buyers
Thane
Thane
Dana Point, CA
10 FJ Cruiser, 21 JLURXR
IFS in the FJ with sway bar entirely removed 24/7, runs great on washboards, just fine at freeway speeds and greatest articulation alway available over obstacles. Increased spring rate helps reduce on street roll. Lifted vehicles already handle like boats, if your a racer automatic disconnects may be better for you... never see dirt you don't need it.
Biggest unknown is if you play in the rocks a lot and want the sway bar with disconnect gone you will end up with a dead "Hero Switch" and an unhappy computer that may treat you to a light show.
Hey19
JJ
Bethlehem
BossMann
Louisville
2009 Honda Pilot
For me? Very....
For many others? Not very....
Halfsmoke00
Kenny
Illinois
'09 Ford Escape AWD V6, '91 Plymouth Acclaim V6
I wonder what the cost would be to get it as a DIO?
Philly
Dallas, TX
2022 JL Rubicon
It’s probably not worth it. I looked into it on my JKU, but the cost was in the thousands and a set of manual quick disconnects is probably less than $100. A lot of the higher end Jeep lift kits even come with quick disconnects.
If you must add it afterwards, I would try and find a totaled Badlands or First Edition to pull it from. They will be hard to come by though. People scoop up front axles and sway bars from totaled Rubicon’s quickly.
Gamecock
It’s important to me...I’m sold on it. It’s a pain to disconnect and reconnect IFS swaybars. It’s hard to even find manual disconnects for Rangers and Tacomas, making me skeptical about them being readily available for Bronco, and I want a swaybar for the street, so I’m not taking it off. It’s worth it.
Rick Astley
Up Doug's ass
d
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
My thinking is that I'll have to get out of the vehicle to air down the tires at the start of any serious trail anyway, so wouldn't that be a good time to manually disconnect the swaybar? I'd still prefer the electronic disconnect, of course, but a manual disconnect doesn't seem like it would be that much less convenient.
