How do I remove the strut top hat?
Tybh88
Tyler
different strut with similar situations I'd compress the spring to where is still had pressure on the top hat to hit it with a impact gun. Light work.
dgorsett
colorado
F250, Mustang, Explorer
A vice grips holding the shaft with a rag to protect the shaft is what I had to do. If you have the right tools (offset wrench) you should be able to key an allen to hold the shaft
I used vice grips up high, out of the stroke range of the shock
Techun
Pa
BD, 2.7, MIC, 4dr
Ford Bronco How do I remove the strut top hat? IMG_20251021_151221487
Ford Bronco How do I remove the strut top hat? IMG_20251021_141330227
I've given up on removing this top hat and just went back to stock. The (probably failed or soon to fail) badlands bilsteins just aren't worth this process.
ouch
Techun
Pa
BD, 2.7, MIC, 4dr
Well I hated feeling like a quitter, and didn't feel comfortable knowing that nut was 3/4 of the way off after I reinstalled it. So I tried again.
First was vice grips on the shaft.
Then vice grips on the shaft and my uncle's high torque impact.
Then a series of dremel, punches, chisels, etc.
Ford Bronco How do I remove the strut top hat? IMG_20251023_145353752_HDR
Literally nothing worked. About to give up but figured it's already ruined let's drill/drain the shock body and cut the shaft.
Ford Bronco How do I remove the strut top hat? IMG_20251023_153821476_HDR
Success. All this heartache for one stupid tophat! And if it wasn't recessed like that it would have never been an issue lol. So...one corner is done!
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I actually told you to put some heat on it. This is like a troll right?
Techun
Pa
BD, 2.7, MIC, 4dr
Well my goal is to save the tophat. We briefly tried putting heat on the problem nut but it's surrounded by rubber so that's a no-go.
Tonka Bronka
Duncansville
All you have to do is protect the rubber with a small piece of tin or fire proof material. I’ve removed many this way so yeah, it’s not a no go.
Techun
Pa
BD, 2.7, MIC, 4dr
Well now I know. I don't own a torch, don't have experience with that. I'm going to do the second rear today, I bet (hope) it comes off smoothly with no drama
Techun
Pa
BD, 2.7, MIC, 4dr
Success on the second one, but it was still a PITA. I had to pick mud and crud out of that recessed cup the nut sits in. So everything was pretty rusty. Used a brush to clean everything and the threads and put anti-sieze on the visible threads in hopes to lubricate it's journey up.
The initial movement of the nut took a LOT of force. Then it was pretty easy to move, I went 2 steps forward one step back the whole way.
The PROBLEM though, is by the end you're still on the threads and you completely run out of post to grab?! What kind of idiot design is this? I much prefer the kind where you put a hex key down into the post, you won't run out of depth there. However, vice grips on the shaft did grip enough to get it off. Phew.
Also realized I'm an idiot and if I compressed the spring even more I can expose the whole nut....so we could have more easily cut that nut off the first one. Doh.
Ford Bronco How do I remove the strut top hat? IMG_20251024_112530119
Ford Bronco How do I remove the strut top hat? IMG_20251024_112351506_HDR
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
I actually used a little WD-40 and started to loosen the nut with the spring pressure still on it, have to be careful. Once its starts to loosen then use spring compressor.
If you haven’t discovered PB Blaster I highly recommend it. Soak, drink a beer, and it will probably come loose after that without needing the grinder. 60% of the time it works every time.
it smells like an old dude’s sweaty socks though
Techun
Pa
BD, 2.7, MIC, 4dr
I sprayed it thoroughly with PB blaster as the very first step!
