How do I remove the strut top hat?
Techun
Pa
BD, 2.7, MIC, 4dr
The nut is recessed in the top hat...what tool do I need to hold the strut piston and loosen that top nut at the same time?
(I have a spring compressor to remove tension)
Techun
Pa
BD, 2.7, MIC, 4dr
Ford Bronco How do I remove the strut top hat? IMG_20251020_123532811
kodiakisland
Arkansas
Impact wrench should remove it
Techun
Pa
BD, 2.7, MIC, 4dr
Techun
Pa
BD, 2.7, MIC, 4dr
No luck yet today. That earlier pic offset wrench was slightly too big. Had to order an 18mm offset wrench, don't seem to exist in my local stores. What a PITA this is becoming.
Also removed the rear lower shock bolt by hand 💪. That was... difficult.
andersman02
Garrett
Minnesota
Bronco Big Bend 2.7l SaS
A vice grips holding the shaft with a rag to protect the shaft is what I had to do. If you have the right tools (offset wrench) you should be able to key an allen to hold the shaft
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
You are probably going to need some heat on that nut. Be careful not to ruin the rubber in the hat.
Techun
Pa
BD, 2.7, MIC, 4dr
It's not an allen like many others are. It's a 5/16ths post and the nut is recessed. I hate it :)
Jazer
Jessica
2.7 OBX
Replacement coilovers ftw. Lol
Also, my air impact couldn't remove the rear lower bolts but it was cake with a cheater bar.
23OBX2.7
AB Canada
2023 Bronco
I always use breaker bar before impact because impacts can do a lot of damage in no time.
andersman02
Garrett
Minnesota
Thinking back your right. Still the same though, had to use a vice as I didn't have an offset wrench
Earl
Nevada
2025 Bronco
Just be careful with that style of spring compressor! I did find that if you are upgrading your springs (I went from stock to the Eibachs), that style would not compress the new springs enough to reassemble the strut.
Techun
Pa
BD, 2.7, MIC, 4dr
Well that would be ...quite the pickle. These are stock badlands struts and springs I want to reassemble.
broadicustomworks
Hanging Rock, North Carolina
It will work.
I used the same style.
Just be mindful of them as you use them, make sure you tighten evenly, they are mostly directly across from each other, and all that jazz.
I've used the same style of compressor on a dozen sets of springs for various jobs and no issues.
I even bought a floor-style compressor that looked like it was going to be the best thing since sliced bread but proved to not be nearly as useful as the simple ones.
