- First Name
- Michael
- Joined
- Aug 11, 2023
- Threads
- 8
- Messages
- 86
- Reaction score
- 107
- Location
- Brigham City, Utah
- Vehicle(s)
- 2023 4-door Wildtrak in Hot Pepper Red
- Your Bronco Model
- Wildtrak
Thanks @adamruiz2001 !
I did install it myself.
After finding a YouTube vid suggesting dropping the inside of the lower control arm instead of the way the directions say (pull axle nut and rock hub assembly down.
I also needed to clearance a hole on the diff drop bracket. The screws on top of my shock assemblies were threaded to the end though appeared to be same length as pics in instructions so I ground em down, and had to chamfer the studs and chase the threads.
It took me a long time because axle nut thread got chewed up and I had to order a new one. I think if you knew going in to drop inside of lower control arm vs rocking the hub assembly down, and you knew to expect slight mods with drop bracket and heat shield, it's a pretty quick and easy job.
I had one final scare... I (or maybe alignment place) bent a dust shield on back of the rotor and it led to a scary sounding problem I thought was way worse than it ended up being.
I agree with others that the ride quality seems identical. At very first, I thought it was possible it was slightly bouncier... But I think that was more in my head. For the price I'm happy.
It does come with one.Looks like the RC 2.5 lift doesnt come with a Dif Drop, did you buy one separately?
I was just reading the info on the site and looking at that same picture which I was going to post. You beat me to it. Lol I was told that the black metal L shaped piece to the upper right with two holes in it was the diff drop bracket.Interesting, I guess they just excluded it from the pictures on their website..
Well if you look at the three and a half inch lift kit and look at what it says is "in the box" and then look at the picture in that one it says it has differential drop brackets but I don't see them in the picture. Other than two extra spacers and the lift pieces being a little different it basically looks like the same kit, so I'm not sure.That looks more like a track bar relocation bracket to me (for the rear). I think you would need more than 1 bracket for the dif drop and usually there a much wider bracket, like below that's in the 5" lift kit.
Well if you look at the three and a half inch lift kit and look at what it says is "in the box" and then look at the picture in that one it says it has differential drop brackets but I don't see them in the picture. Other than two extra spacers and the lift pieces being a little different it basically looks like the same kit, so I'm not sure.![]()
Texas Dan that put this kit on himself, and I remember when I questioned him he said that the one that I pointed out to you was the drop bracket. My installer I believe also told me it was a drop bracket for the front diff.Well if you look at the three and a half inch lift kit and look at what it says is "in the box" and then look at the picture in that one it says it has differential drop brackets but I don't see them in the picture. Other than two extra spacers and the lift pieces being a little different it basically looks like the same kit, so I'm not sure.![]()
Also the bracket you show in the picture is usually for a complete drop bracket system like I put in my Tacoma which was a 6-in lift they cut out the whole crossmember and installed a new one. I believe this is done differently but I could be wrong just telling you what I think I know even though I don't know for sure.🫤That looks more like a track bar relocation bracket to me (for the rear). I think you would need more than 1 bracket for the dif drop and usually there a much wider bracket, like below that's in the 5" lift kit.
Just to let you know, a system like that is very invasive and I swore once I did it to my Tacoma I would not do that to another vehicle. And you are correct on a two and a half inch lift with new upper control arms normally you don't even need a differential drop so the fact that it comes with a small version of one which is very uninvasive to keep the geometry as stock as possible for the CV joints along with the new upper control arms and for the price that it is, I don't see how you can beat it! If you are good with two and a half inches of lift that is! I am super happy with how mine turned out and I put 37's on with absolutely no issue at all. Also love the ride!Ok you are correct, I looked at the install document and it uses the bracket you pointed out on the drivers side and a few spacers to drop the passenger side, so it looks like a minimal drop so they didn't feel the need to do the whole bracket, which shouldn't be too big of a deal since most other kits do not drop the dif at all unless there above 3.5"
I kind of like the Belltech lift it comes with the full Dif drop as well as a new lifted steering knuckle, claims stock geometry but not sure if that would work with the Hoss 3.0 suspension..
Just to let you know, a system like that is very invasive and I swore once I did it to my Tacoma I would not do that to another vehicle. And you are correct on a two and a half inch lift with new upper control arms normally you don't even need a differential drop so the fact that it comes with a small version of one which is very uninvasive to keep the geometry as stock as possible for the CV joints along with the new upper control arms and for the price that it is, I don't see how you can beat it! If you are good with two and a half inches of lift that is! I am super happy with how mine turned out and I put 37's on with absolutely no issue at all. Also love the ride!Good luck with whatever you do.
yea thanks! Not sure how it’s invasive I don’t think there is any cutting of anything needed but I’ll take a look at the install instructions, I won’t be cutting up things for a lift so that would be a no for me. Yours looks great!
I checked
You do need to cut up the crossmember not going there! Lol.
