Horrible window rattle if opened partially
MikeC51
New Jersey
Colorado ZR2
Hi All,
Is there anything I can do about a very bad window rattle if the windows are partially opened?
It sounds as if the may break under normal driving conditions. I have brought my car in for this and was told there is nothing wrong.
The Drivers door also catches on the top lip as if tis not dropping in time when I open the door at times.
thanks for your help or suggestions.
P.S.
Anyone's hood open alarm for off for no reason?
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
Hi All,
P.S.
Known issue. Ford was supposed to have a fix for it last year but they pushed it back to later in 2024
userdude
Denton, TX
2023 2dr Badsquatch
There are ways to adjust the window. You might try another dealer service. I told mine about some issues they couldn't replicate (specifically, the window closing on the seal instead of in it) and they did do an adjustment anyway.
You can also adjust the bump stops if you're having a lot of flutter on the hood at higher speeds.
The window closing on the seal, someone said if you touch the handle, pull away slightly, then do it again, it "wakes" the truck and the window works right. I always forget and it tends to do it when it's been sitting overnight (happens a lot in the morning in the garage). Maybe Ford will fix that, but I think that itself was a fix.
WheresMyBronco
Los Angeles
2023 Badlands
Open your door and look at the bottom. You'll see 2 rubber plugs. Remove those and get a 10mm socket. Loosen the bolts, push them outward (away from the Bronco) as much as possible, and then retighten them. Should help with the window shaking quite a bit.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi All,
P.S.
Good afternoon. If you'd like, would you send over a private message with your VIN and dealer info so I can look into this window rattle concern on my end? Thanks.
Shane78
Shane
St. Louis
2D
Don’t take it to the dealer. They are gonna do the same thing and charge you several hundred for it, if not more. Do what @WheresMyBronco said. Look up window rattle on YouTube if you want a demonstration, should fix your issue.
Ducati1098
Adjustments help, but now I drive either all the way up or all the way down.
Yeah the adjustments don’t fix the issue. Which is why Ford removed that TSB.
They’re still working on a fix for the concern. Current information is Q3 of this year.
Shane78
Shane
St. Louis
2D
I don’t have a reference point, because I did the adjustment and mine stopped rattling full stop. So others still have the same issue even after adjustment?
Ducati1098
Yes.
I’ve adjusted mine which were really bad, and it’s certainly better. But there are still plenty of times I’ll hit a bump and they’ll rattle.
LCW
Twin Cities, MN
2019 4R TRD ORP, 2023 Bronco 2dr Badlands (gone)
Yup - my 23 does this. Window cracked anywhere between 1-3"... hit a sharp bump (because the suspension tune is shit) and you'd swear the window is going to snap in half.
kodiakisland
Arkansas
Yep, most all do it. The fix is all the way up or all the way down. Sucks, but you've got to work with what you've got.
MikeC51
MikeC51
New Jersey
Colorado ZR2
why would this not be covered under warranty
MikeC51
MikeC51
New Jersey
Colorado ZR2
DM’d you. Thanks for looking into it
BigBlue7
New Jersey
It will be once they announce a fix for it. They haven't released it yet
