66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
Folks, don't be fooled . . . a well organized, fully stocked First Aid Kit will be of little value if you don't take quality time to understand basic First Aid treatment techniques. A few have posted in this thread similar thoughts, but it cannot be stressed enough. It is clear that some who have posted here are very experienced and would know what to do, but probably the average B6G poster has no medical background or knowledge of basic First Aid techniques. Therefore I would argue that a good First Aid instructional book is as important as the First Aid Kit itself. Here is a recommendation:
https://www.amazon.com/ACEP-First-Manual-Step-Step/dp/1465419500
Tip: Read and be at least lightly familiar with the material when you first get the book, then keep it under a seat or in a permanent storage spot in your Bronco. Don't wait until there is an injury or other medical emergency to open the book for the first time. 😕
This!
  • Like
Reactions: sjp
mbagne
Matt
Placentia, CA
Mach-E GT
And I should have added . . . just using a book is the lazy man's approach . . .the BEST path is to take an actual course in First Aid. You can look up a source in your own community . . . the Red Cross and often local fire departments or even hospitals that sponsor community classes can be effective. If you have time, do this in conjunction with the book.
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I agree that a lot of companies make great kits but I have found that if I build one myself, I know what is in there and some of the stuff that companies include are poor quality (adhesive bandages with poor adhesive?). Build your own with stuff you know you will use.
joez
parts unknown
bronco
I think you would be better off mounting the seat-belt cutter/window punch somewhere near the driver seat that you can reach it. It does you no good if you are trapped and you can use it, because its in the back.
The other thing I do with my 1st aid kits is put all the items that expire in a zip lock bag. If I am not going to use the car for a while, I pull the bag an bring it in the house. Heat isn't good for your meds. Plus, it is easier once a year to go through everything and replace what has expired.
Inakomislu
Inakomislu
usa
bmw
I also make sure mine is within arm's reach, just in case. As for the first aid kit, I love the idea of putting the expired items in a zip-lock bag to keep track. I actually learned that the hard way when I went to use a bandage during a minor cut and realized it was way past its expiration date. Since then, I started using Raven nitrile gloves from harmonycr.com in my kit, too. I had to help a friend with a small accident, and those gloves made everything so much easier—clean, comfortable, and reliable.
Easy-v
U S A
BadSquatch
Thanks for starting this thread was looking to put together a kit for my Bronco!
SeptuagenerianSasquatch
Randy
Massachusetts
Feminine sanitary napkins are better. Individually wrapped and sterile.
I keep two infant-size diapers for major blood flow, like an abdominal wound. A sanitary pad could be just the thing for a smaller laceration.
The Red Cross blood donation people use tape like this. I just might get some. Not an adhesive type, but a wrap-around, strong and holds well. I'm thinking if there's a lot of blood or other fluid on a limb, you could apply the pad then wrap this around the arm or leg. Use on a torso sound, probably not so good:
Ford Bronco Homemade First Aid Kit 1734670838944-ka
