Hinge Lights
DjMojon
Jose
Baltimore
2022 Badlands
CalvinT
Calvin
Phoenix, AZ
Turnoffroad doesn't have any documentation on their website. The mounts look like a good idea, but the lack of documentation isn't a good sign. They removed the video that used to be on their site. How they route the wires is unclear.
As far as connectors. There are some good kits on Amazon for weather proof connectors.
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
I’ve consider picking up the mounts for the rear hinges, the video I watched has them routing the wiring under the weather stripping for the rear glass.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
I don't know if they still have the image posted. But I captured this awhile back as I thought it was a lapse in truth in advertising. "...Without drilling, cutting, or modifying your HT". - just ignore the janky drill holes in the hinge cover to accommodate the wire. 🙄
Ford Bronco Hinge Lights 1770124400841-1h
EffenNewGuy
Eduardo
'02 Silverado LS, '14 Subaru Impreza Sport Ltd
Has anyone installed any S2 lights on their hardtop hinges. I'm looking at this set from Turn Off Road (https://turnoffroad.com/products/2021-ford-bronco-oem-hard-top-hinge-light-bracket) and will probably use some Diode Dynamics lights. I'm curious to know how people have installed them. Where are you wiring them to, and how are you unplugging them when removing the roof.
Hi OP. I did this very mod a couple of weeks ago. Used S2 lights mounted on @Turnoffroad hinge brackets.
EffenNewGuy
Eduardo
I opted to route the wire down the outer side of each hinge and went under the weatherstripping. Joined both light pigtails into one connector and used the ground behind the passenger side panel. Used a Deustch connector to be able to disconnect lights and remove the top.
Ford Bronco Hinge Lights IMG_5611
Ford Bronco Hinge Lights IMG_5613
Ford Bronco Hinge Lights IMG_5614
EffenNewGuy
Eduardo
This wiring diagram was extremely helpful. Pic of my Bronco with lights freshly installed.
Ford Bronco Hinge Lights IMG_5402
Ford Bronco Hinge Lights IMG_5403
EffenNewGuy
Eduardo
Here’s my Bronco during a wheeling trip last weekend. Lights held up just fine and did not loosen up at all.
FYI you won’t be able to use the hardware provided with the S2s (bolt is too thick), but the hardware provided by turn works just fine. I had to add a washer because like a dum dum I tried to use the thicker bolt and drilled out the slot on the bracket.
Ford Bronco Hinge Lights IMG_1223
DjMojon
DjMojon
Jose
Baltimore
2022 Badlands
This is exactly what I was looking for. It looks awesome!
