High Mount Winch Plate installed on Capable Bumper
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
Getting around to working on the wife’s Wildtrak. Been looking for a mount that checked all my boxes with things like sensors and camera relocation, high & tight mount, bull bar, etc.
Ford Bronco High Mount Winch Plate installed on Capable Bumper 3BF17725-1DE9-4A1C-9BF1-A9C44857AAE2
Ford Bronco High Mount Winch Plate installed on Capable Bumper 8995ADCD-8333-490E-9621-030DB5CCAAC4
Ford Bronco High Mount Winch Plate installed on Capable Bumper AC8A265D-EAB5-464F-971E-257F7D57F8BE
Ford Bronco High Mount Winch Plate installed on Capable Bumper 02767B38-D9A8-42A8-875A-B3679D14DB16
Ford Bronco High Mount Winch Plate installed on Capable Bumper CD94372B-DA6D-45B9-B241-AE4327D4A5C5
Ford Bronco High Mount Winch Plate installed on Capable Bumper 12E2AA9D-A7ED-48FE-AC9A-E278097C5A9E
Ford Bronco High Mount Winch Plate installed on Capable Bumper 23498449-A671-4534-8BBF-AFDB93466FA3
Ford Bronco High Mount Winch Plate installed on Capable Bumper 8AB12FE5-681E-4B1E-A4C7-36F946C006F2
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
Are there any reinforcements to the plates at the end of the frame horns? Those are known to bend when used for recovery. The mount adds a lever to to the mix which is only going to torque them more.
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
I’d say no more or less than the Ford Performance model when installed. The winch mounting brackets are pretty beefy at the mounting point.. Additional the recovery point is directly in line with the mounting point and frame, so the force should be transferred directly and not at a leveraged angle like some of the other offerings I’ve seen the last couple years. This is the first one that fit what I was personally looking for. The capable bumper has been the red-headed step child of development.
67BroncoG1
Ron
CA
I’d say no more or less than the Ford Performance model. It’s pretty beefy at the horns. Additional the recovery point is directly in line with the mounting point and frame, so the force should be transferred directly and not at a leveraged angle like some of the other offerings I’ve seen the last couple years. This is the first one that fit what I was personally looking for. The capable bumper has been the red-headed step child of development.
Do yourself a favor and install these:
https://lodoffroad.com/products/2021-bronco-black-ops-front-bumper-frame-tie-in-brackets
Cheap insurance for when you need to use that winch.
scotman623
Saratoga Springs NY
Chevy LT Trail boss
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
RC Bronco
Kansas
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
i just got mine installed a couple weeks ago. Really looks great up front :D
Ford Bronco High Mount Winch Plate installed on Capable Bumper 20231103_123826
Ford Bronco High Mount Winch Plate installed on Capable Bumper 20231103_135809
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
Love the color! Very clean install. I like what you did with the lights.
I’ve got a set of bar clamps and KC Pro Gravity 6 for the bull bar, but I kind of like what you did. I could put the KCs on the pillar. 🤔
How did you get the camera bracket behind the plate mount?
Mines sandwiched between the fairlead and the mount. It wouldn’t line up with the holes when I tried to put it behind. It conflicted w/ the badland fairlead.so I ground off the letters, buffed it, and flipped it.
Ford Bronco High Mount Winch Plate installed on Capable Bumper A1A2E901-6878-401F-A85C-19B0771CA260
