Heritage Stripe Portion
Godsey1
Tony
Crossville, TN
1978 Dodge Aspen
I just got the front heritage stripes for my upgrade to the heritage limited look from a regular heritage. The weird thing is, they are different prices. I had a 12% off coupon.
Ford Bronco Heritage Stripe Portion 20250606_184603
TheShark
pharden
Paul
Newport, RI
2019 Ford Edge ST
I don't think anyone does. Besides, you'll want to replace the entire thing. Anything you buy is going to be a lot higher quality that what Ford puts on there. I have a 2023 Heritage 2 door and I hated the vinyl script. I bought the Heritage spear set from Underground graphics and had a local shop put it on for me. He showed me the Ford pinstriping he took off and it was very thin and cheap. He said the pinstripe from Underground was a very high quality vinyl and much nicer than what Ford uses. I added the original Bronco metal script as well, to match the Heritage Limited. Big upgrade.
I’m in Rhode Island too in Newport. If you don’t mind who did you use to install the stripes as I’m thinking about adding stripes to myOBX.]
King63
Lee
Oregon
24 Heritage, 18 Honda CRV
True. They aren't exactly cheap.
Do you know if the Heritage stripes are applied on top of the clear coat and then clear coated themselves, or applied to the vehicle before clear coat and then clear coated along with the rest of the vehicle?
Ducati1098
I would guess they’re just applied on top of the clear coat, but I’m not 100% sure.
I wouldn’t think they would add any clear coat over the decals.
King63
Lee
Oregon
I'm assuming that they applied the stripe over the clear coat too, but wanted to be sure before I pull them off, because I'm not planning on replacing them at the moment, and didn't want to then find out that I had a "stripe" of un-clearcoated paint down both sides! I'm going to add the badges on the front quarters and then see how I like it without stripes, since I can always add the stripes back in the future.
Godsey1
Tony
Crossville, TN
1978 Dodge Aspen
Got mine finished. I think Ford put the stripes on wrong. I think they put them too low. All of them that i have seen has the wide top stripe at the bottom of the dip that run through the side of it. I think that part of the stripe should run in that dip.
Ford Bronco Heritage Stripe Portion 1000016159
Ford Bronco Heritage Stripe Portion 1000016160
TheShark
I don't know, looks pretty darn close to what I have.
Ford Bronco Heritage Stripe Portion 81DC7C85-89C4-4C31-AE75-5F9AA9F3B272_1_105_c
Godsey1
Tony
Crossville, TN
1978 Dodge Aspen
Thanks for the picture and information. I love the yellow Bronco's.
