Help with badlands new wheel offset.
Havanajoe
Sarasota Fla
Audi S5 coupe. Tesla Model Y
So I have a non SAS badlands and am doing a rpg perch lift and want 35” nitto‘s with Icon Rebound wheel I can’t wrap my head around the offset to get the tires to the outer most rim of my standard flares or maybe 1” past any help is apreciat3d.
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
Zero offset should get you almost 1” poke outside the flares.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Currently you have +55 offset,If you want them to poke 1” out you probably need 0 off set. My 0 offset with Sasquatch flares are even with the flares.
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
I have non SAS Badlands and went with +18 offset which I think is nearly perfect. I wouldn't want any more poke. I found one wheel that I liked with a +25 offset which I think would have been perfect, but I liked this wheel better, with +18. Personal opinions here. I was surprised by how much it changed the look going to the +18 from the stock +55, I initially didn't think I liked it. But, it grew on me and now I like it.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
Need to factor in wheel width when looking at offset.
Badlands non-SAS is 17x8 +55. SAS is 17x8.5 +35
Any 8.5/9x wheel w/ 0 to +25 will get you in the direction asked.
17x8.5 +18 w/ OE 33” (285/70r17) KO2
Ford Bronco Help  with badlands new wheel offset. 9DF1D4F3-B9CD-40BA-A505-EB7E58A1A5BE
Same wheel. 35x12.5r17 non-SAS. No lift or level.
Ford Bronco Help  with badlands new wheel offset. F9C6EC1B-E719-4D83-8D17-21D9FE022CDA
I have a GRT 1,25” front-only perch collar lift If I need to install it,
Copperhorse73
Justin
Mooresville, NC
The concept of both width and offset affecting backspacing (a more important measurement) is often overlooked. My rule of thumb to get perfect poke would be 0 offset on an 8.5” rim or -12 offset on 9” width. those are 2 most common width/offset combinations I see in the wheel brands I shop
Shoresy
Land cruiser, focus st
Here’s badlands on +55 offset,8”with 37mm (1.5” hubcentric spacers). So equivalent to +18 offset. 315/70r17 tires.
Ford Bronco Help  with badlands new wheel offset. 3B66BBD9-62F3-4576-BD60-979631F89AD1
‘21OBX
90Bronco19
2022 bronco outer banks
These are the wheels I went with a nd pics these are 37”x12.50/17 nitto Terrell grappler G2. These are +18 8.5” wide
Ford Bronco Help  with badlands new wheel offset. A7A161E3-7FD6-4406-B4A5-905C10FC1723
Ford Bronco Help  with badlands new wheel offset. A127BF25-06DA-442F-B7F5-934F50E1D630
Ford Bronco Help  with badlands new wheel offset. 5A3C9579-88DE-4462-A570-4C1A9957F657
‘21OBX
90Bronco19
Havanajoe
Havanajoe
Sarasota Fla
Well after looking and measuring I think +18 may be what I want if I had SAS flares then 0 would be good but will poke too much on my non SAS flares.
I like the poke on ‘21OBX OB
Thanks guys so far.
GorillaGrapplr
Tim
Wheeling WV
2021 Ford Bronco Badlands 2.3 Area 51
so if I put sas flares on my non sas bronco 0 offset would be even? Would there be any rubbing?
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
peterh
ny
jeep wrangler jlu 2018
Would love to see some pictures of your set up - sounds good
