HELP NEEDED - Spare Brake Light only illuminates when in accessory mod
tymccullough
Ty
Austin TX
Explorer XLT
Spare brake light only illuminates when in accessory mode. Once car turns on, tire light and above tire light don’t work when brake is pressed. Any help is appreciated!
Ford Bronco HELP NEEDED - Spare Brake Light only illuminates when in accessory mod IMG_5218
Ford Bronco HELP NEEDED - Spare Brake Light only illuminates when in accessory mod IMG_5219
Have you made any Forscan mods to it?
And have you checked with it in gear running?
tymccullough
Ty
Austin TX
Explorer XLT
No Forscan mods, and yes while in gear and brakes are pressed nothing happens.
RagnarKon
Ford Bronco, Escape, Focus
I'm guessing there is an adapter harness for the wheel stop light you bought that plugs into factory harness somewhere.
Where does it plug in??
tymccullough
Ty
Austin TX
Explorer XLT
I fed the wires from the spare to the plastic compartment on the right side of the interior part of the tailgate- these are the instructions from stickerfab where I got the product.
Ford Bronco HELP NEEDED - Spare Brake Light only illuminates when in accessory mod IMG_5223
RagnarKon
Have you tried putting it back to stock to see if the high-mount taillight works as expected without the tire light?
I have a suspicion it is wrong farther up the wiring harness.
tymccullough
Ty
Austin TX
Explorer XLT
Thank you for your reply :)
Yes, I put it back to factory and everything works properly. I use the adaptor for the spare light and only works in accessory.
RagnarKon
Theory busted. So moving on...
So the yellow/grey wire on the factory harness should line up with the positive red wire on the adapter. The black/green wire on the factory harness should line up with the negative black wire on the adapter. It probably is... if it wasn't the LEDs would be reversed biased and not work. But double check it.
And another thing to try: Does it work properly while leaving the factory high-mount stop lamp unplugged?? Effectively only using the tire light.
Mjasi3
Chicago
@StickerFab ’s issue to help. They should know / have ideas
StickerFab
Fort Myers
www.stickerfab.com
2021 Bronco Badlands / 2023 Bronco Raptor
StickerFab
Fort Myers
www.stickerfab.com
tymccullough
Ty
Austin TX
Explorer XLT
Thank you everyone who has been helping! I’m talking with stickerfab!
RagnarKon
Should let us know when you figure it out.
(My theory is BCM is cutting power.)
