Help Identifying Mystery Retainer
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
This plastic retainer showed up on my front passenger side floor after I went wheeling with a friend. I'll be damned if I can figure out where it came from. I assume its an interior bit related to the front, but maybe a service tech accidentally dropped it and it came from somewhere else entirely. Any suggestions where to look? @Ducati1098?
Ford Bronco Help Identifying Mystery Retainer PXL_20250824_192529322~2
Ford Bronco Help Identifying Mystery Retainer PXL_20250824_192540598~2
Ducati1098
Holds the carpet down. All the way at the front, near the feet. Should be a stud it can slide onto
Ford Bronco Help Identifying Mystery Retainer IMG_8399
ThunderFlash
ThunderFlash
Doug
Washington
You Sir are an all-star! Of course it wouldn't go back on threading, then pushing and threading and now its broken...but at least i can sleep soundly having that life mystery solved. Hard to see that hole under the dash in black carpet and the carpet had moved hiding the painted stud.
