Help adjusting Eibach coilovers
Solfive
NV
2008 JKUR
I just installed Eibach Pro-truck 2 coilovers on a non-squatch badlands. I have a couple of questions about adjusting final ride height. My goal is to have the rear at the lowest possible setting and the front level with the rear to reduce the need to replace control arms:
1. When I’m adjusting the collars do I need to lubricate the shock body threads? If so, using what ideally?
2. This feels like a dumb question with an obvious answer but I’d kick myself if I didn’t ask to be safe…to accomplish the smallest amount of lift height do I just simply move the collar to lowest available thread?
Thanks in advance for the guidance.
omi205
BoJack
Austin
The vehicle has to be lifted before you can change the hight. As in wheels hanging. Not sure about the rest.
PWillette
Parrie
Maine
I have the Eibach 2.0s, very happy. As mentioned above, you'll want all the weight off the suspension...jack stands/lift on the frame. No lubrication is recommended...they do go pretty dry and the Eibach tool isn't the greatest so go slow. With that being said, it's easier to adjust down vs. up. I'd recommend first installing as they are out of the box and put a couple miles on before making adjustments. There should of been install instructions showing the minimum and maximum collar adjustments...if not check the website for instructions. You won't want to go all the way down on the threads.
Solfive
Solfive
NV
2008 JKUR
Thanks! Unfortunately there weren’t instructions in the box but I’m going to check their website for them now.
PWillette
Parrie
Maine
On the rear you'll want to leave 1/2" of threads exposed so that you have the ability to fine tune. If you go all the way down you won't have room to fine tune other than going up.
Solfive
Solfive
NV
2008 JKUR
Excellent! Sounds like a good starting point to me.
Spooled
Republic of Texas
Raptor, Model 3
The stock UCA's are actually pretty good. On a friends rig we lowered the fronts and ended with 2.25" lift at the front of a 2-Door OBX and we lowered the rears almost all the way. Alignment was able to be brought in spec with the stock UCA's.
Ford Bronco Help adjusting Eibach coilovers 1706717464340
Solfive
Solfive
NV
2008 JKUR
Thanks for the reference points to work off of! I’d rather be a little low than a little too high to save CV angles and replacing other components prematurely. So your guys help is appreciated!
MC1313
DolphinsMark1313
2023 Bronco
I was wondering how your set up worked for you? I was also thinking to set the rears all the way down to the lowest setting (2.4”) and then setting the fronts at 2.5”
Solfive
Solfive
NV
2008 JKUR
This approach has worked well for me. It drives great and seems more planted around corners and during emergency braking. No regrets.
CarmeloS
Carmelo
Central Jersey
So glad I found this, I was gonna ask all this as my rear gets squirrelly and lifts when I brake hard (like yesterday with shore traffic on the Garden State)
CarmeloS
Carmelo
Central Jersey
2 quick questions; Would this work, as I can’t find the original piece, and whats ideal for low height, should I do the lowest or? I didnt wanna be more than an inch higher, so want to get an ideal min lift set up going here
Justinfro
Justin
Tulsa
4Runner, Cayman S (987.2), 911sc
Yes, that spanner wrench is pefect for your needs. As far as minimal lift, set it to the lowest setting which still yields like 2.5-3.0" lift over stock.
CarmeloS
Carmelo
Central Jersey
So 0.8 Front/1.7 Rear? Just wanna be sure.
Appreciate it, wanna be one and done with it
Justinfro
Justin
Tulsa
I set the rear to max low, then adjusted the front minimally to get a very tiny rake. it defini took some adjusting and driving around to settle the suspension to fully dial it in.
