Heated steering wheel on Lux package
Snowdogyyz
23 Ford Bronco Wildtrak
I’m positive.
Not that anyone on this forum cares but the heated steering wheel on my Gladiator worked great and provided exceptional warmth to my fingers on many a chilly doors off day.
I had a gladiator as well. The bronco steering wheel gets nowhere near as warm- although mine goes get “warm”.
Roll Tide!
Roll Tide!
Robert
SW Florida
4 Door Carbonized Gray Wildtrak
The stock setting isn't the warmest I've ever had on a steering wheel, but if you feel absolutely no heat, then it isn't working right.
The heated seats are really good though. If you go commando you might get a burn.
Yes, no heat at all.
seats are perfect however.
if that’s the worse thing I experience being a new Bronco owner then I’ll be happy.
Wildfire1
Paul
Nfld, Canada
1993 GMC 4X4 / 2012 Mustang convert
It must be a regional thing because our Luc OBX steering wheel is hot hot hot and the seats are the same way.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
I've not had any problems with mine. Used it numerous times this past winter and was quite happy with it. 🤷‍♂️
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I would say mine gets “warm” and in specific locations. But that’s all that’s need IMO. Warms my hands well
Shazamalingo
West
2022 OBX SAS
Just picked up my Wildtrak one week ago. Thought I’d try out the heated steering wheel tonight and no heat. Anyone else experience this issue when they first bought their Bronco?
Hmmm. Mine gets hot rather quickly, even in 0 degree weather...
Dral97
Ford Bronco, Wrangler YJ, LJ, and 392, BMW 4 series
Mine's in the 'warm but not hot' group. Definitely noticeable pretty quickly though.
xusarmy
Todd
TX
2021 Ford Bronco Outer Banks
No issues with mine, that thing gets hot in a hurry
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there. I can look into your Bronco’s heated steering wheel concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
MayhemMike
Mercury
If I leave my steering wheel heater on I have to wear oven mitts . The seat heaters allow me to transport oven fresh pizza in the passenger seat . I believe I could cook a meal on the seats on the high setting. BTW, I like them.
Hawke
US-MN
Several
Anyone know if a dealer/service can increase the temp of a heated steering wheel or if it can be done in forscan? Other manufacturers have had this option to increase temperatures by changing a setting/set point. Sounds like this may not be the issue here but would be good to know if this is possible given the range of responses from people. I have a heated steering wheel and it doesn't do much compared to other vehicles I have had, almost worthless.
Combustion_King
Derek
MA
Yes
mine gets hot, i usually turn it off after a bit. but its also hottest at 10 and 2 the bottom the most.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I know there is for the seats that can be changed in ForScan. I hope there's one for the wheel
bytheway
Brice
Louisville, KY
Yes, you can change the heat setting in Forscan, I've set mine higher and have had no issues.
I also turned my heated wheel up. It's almost at max setting and still "warm" but not hot. But it works for me. I wouldn't want the wheel to get as hot as the seats do.
