Hard top peg broken
Jmax
Plymouth
Explorer
So pulled a bonehead spring day move. Pulled the hard tip off for the first time this year and forgot about the two most front bolts…. Realized it as soon as I started pulling the top off but one of the pegs that aligns the top to the body broke off…. It looks like standard fiberglass. Anyone have suggestions on how to fix?
Jmax
Plymouth
Explorer
Is there one specifically made for fiberglass?
ChrisB351
Shreveport, LA
If youre referring to the alignment pins, I broke one myself. I tried to jb weld it back in place but a few times on/off it broke loose. Now I just run with 3.
HeliPilot
Kenny
CT
2022 2.7L SAS
My guide pins are attached with screws. Drill a pilot hole and Run a screw down into the pin from above. That’s how mine came from the factory. A screw similar to this runs down into each of my four guide pins from above.
Ford Bronco Hard top peg broken 96495FEA-4E33-412A-AE35-026B7E9EA13F
Jmax
Plymouth
Explorer
Mine has a screw in it as well but the entire pin broke off….
HeliPilot
Kenny
CT
2022 2.7L SAS
I would think you could source a similar peg, drill it out and screw in from above. You may need to add a washer if the hole in the top is too big. Truth is, you could use a wooden dowel pin from Home Depot.
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
Its shouldn't be surprising how many Bronco parts you can find at Home Depot! :rolleyes:
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I’m surprised nobody has posted a picture of the issue (or suggested solutions) in this thread. Would likely be helpful.
Mlarv
TN
If the Peg itself is broken, I would treat it like a woodworking problem.
Fit the peg parts back together, if they can be reassembled with out any big gaps you are in luck.
Clean each side of the parts with denatured alcohol.
Get a good plastic glue (Gorilla glue)
Wet one side of the part (with water) apply a little bit of glue and tape or clamp it (to hold it tight)
Glue glue squeeze out off hit with flat black paint
Fill it hole in with a little plastic from a pop bottle along with the glue. Remember to wet it a little
When the glue dries drill a pilot hole and reinstall.
