- First Name
- G
- Joined
- Nov 26, 2021
- Threads
- 13
- Messages
- 524
- Reaction score
- 363
- Location
- Sacramento
- Vehicle(s)
- White Wrangler JK, White Bronco Base 2Dr
- Your Bronco Model
- Base
- Thread starter
- #16
Must be a slow day Mr. "Cubed".
Every vehicle is aligned using an alignment machine right after it comes off the chassis line. The measurements are recorded and referenced if a warranty claim comes up. At my old plant the headlights were aligned at the same time.I've heard (from an alignment guy I trust) that some manufacturers "set" the alignment by raw measurement of adjustable parts like tie rods, but only truly align a handful of vehicles off the line. I'm not sure if this is true for Ford or the Bronco, but it could be a contributing factor.
Mr. Sandsux... what model are you driving? I'd think something above a Big Bend or any SAS model would have larger/different brakes than the standard 2DR Base.
I wonder (don't really know) if the software for traction control could be an issue. I remember in someone's Forscan post where you can set the tire size. I assumed this was for correct speedometer, but I wonder if there are any other hooks.
