Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I really like the Rad Designs one. Does anyone have this? Looks like they have a billet version coming soon too instead of the 3D printed. I wonder if you can use Baja S2 lights instead of the wimpy rock lights.
popo_patty
popo_patty
Caleb
Sacramento
My friend was the test Bronco for RAD designs and I’ve been talking to the owner. They have a Raptor version coming out that they exploring billet for. No current plans to change the regular bronco version and no, it doesn’t fit the S2’s.
Ninjak
Miami
The Rad Design one does look really good. I like that.
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
We looked into utilizing the OEM third brake light housing when we were in design phases on ours. Here’s our take on that topic.
Our main mission when we created our modular tailgate reinforcement was to support the weight of larger off-road tires. We realized that the OEM third brake light was designed for a stock height wrangler MT 315/70/17 which measures out to around 34.3”. In most cases when installing larger tires we found that you need to extended the height of the TBL so it can remain effective and have enough Clearence to fit properly. We didn’t like the idea of extending the third brake light and adding more weight to it without any way to stabilize it and ensure it doesn’t bounce around and shake when u go over bumps.
That’s what promoted us to create our third brake light to be fully adjustable and stabilized with a polyurethane bump stop. We wanted our third brake light to be future proof and be able to adapt to any tire size and set the desired height of the owner.
Lastly, our aluminum housing is modular which means you can easily add an antenna mount, rear camera, or even attach a set on Baja designs to the sides if you really wanted to blind everyone behind you.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Is it possible to get some pictures showing the light output?
DoYouBronco
Tyson
El Paso
hpbuilt.shop
The Baja design rock lights were our first choice but after comparing the brightness,functionality, and cost to the made in Austin Texas Fenix LEDs, it was a no brainer. Especially considering our TBL doesn’t rely on dimer imported LEDs for brake/reverse lights.
Baja designs makes epic lights, but for the safety purposes of a chase light, their Rock lights are better than nothing but not optimal for ensuring visibility in dust/precipitation
@popopatty will be getting some drone shots soon, hopefully can do a real world comparison of ours vs others…
DoYouBronco
Tyson
El Paso
hpbuilt.shop
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
@popo_patty love the wiring. Actually made sense to me from the pics as that’s how the Turn Offroad license plate holder is routed through the OEM tailgate grommet. And the SPV harness to power my rear bumper lights is also routed similarly with a pigtail from the driver side rear taillight. And yes that space is snug.
One question- why is the orange chase wire shown in one pic routed near the passenger rear door? I figured it would go in at the passenger rear panel (with the tailgate wiring) and terminate at the rear aux switch wiring.
I do like this chase/brake/backup light combo. Seems to cover a lot of bases. It is expensive, yes, but the quality is excellent. And the wiring harness alone is worth over $100 plus many hours of time.
popo_patty
popo_patty
Caleb
Sacramento
My aux switch wire harness was in that spot near the door. It’s wired behind the panel but I went in through the top due to my diabolical system preventing me from removing the side panel.
popo_patty
popo_patty
Caleb
Sacramento
Here are some stills from some videos I took.
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4312
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4316
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4317
DoYouBronco
Tyson
El Paso
hpbuilt.shop
Big thanks to Casey Wagner for the epic content from last weekends trail session!
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4237
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4193
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. IMG_4239
Ford Bronco Hammer Built 3rd Brake/Chase/Running/Reverse Light Install. 1EB6439E-BB68-4798-BE9F-49D8D99901DF
AIGMUX
Los Angeles
bronco 2022
It's amazing. So beautiful.
