- First Name
- John
- Joined
- Oct 23, 2020
- Threads
- 7
- Messages
- 1,189
- Reaction score
- 2,130
- Location
- Stafford VA
- Vehicle(s)
- Badlands 2.3/Manual and a Gaggle of Jeeps
- Your Bronco Model
- Badlands
- Thread starter
- #1
Bizarre one here, and not sure how to correct it, or if it even matters
I just programmed a Severe Duty Rack, same way I have done many of them now, Forscan to swap vin, FDRS to PMI the rack, Forscan to swap vin back, Back to FDRS to see if anything else needs done..
Everything went as normal, All codes cleared without issue... Forscan thinks everything is fine.
When I go into FDRS however, it pops up a dialog saying that multiple vins are found... Everything matches my original VIN, except the Gateway Module... whitch somehow has the last wrong 5, the first part of the vin matches my original vin fine though.
Can't find any easy way to change it either, and not finding anyone on the interwebs with a suggestion...
I know folks sometimes get used ones out of the junkyard, so there must be a way to change it, but the onlyt suggestions I've found are take it to a dealer.
Anyone ever dealt with this? Any suggestions?
Should I even worry about it, I'm guessing my telematics are going to be reporting a bad vin now...
