Grill letter lights
Viver
Vivian
Ludington
2025 Bronco
I have a 2025 Outer Banks and would like to add the grill letter lights. On Ford accessories page some people said they won’t work on the Outer Banks and others say they will not. I would like to find out what others have to say. I would like the lights to follow the sequence when starting the Bronco, that is showing on the Putco website. Is this possible with the Ford ones sold on the accessories page. I do not have any empty accessory up lift switches. Suggestions?
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
Does your bronco have the front camera?
Brisco2
NJ
2012 F350 XLT, 2018 Ford E350
There is a company on here: SPV parts (@SPVPARTS) that sells an adapter that connects to the headlights without cutting any wires. I use it for backlighting on my fog lights,
Give them a call, they are very helpful with questions and ship quickly.
You could also do a fuse tap for power. You could make any set of grill lights work on the OBX even without the accessory switches.
Big Betty Blue
Amy
Cleveland, Ohio
2025 Bronco
The Ford site has 2 front grill lettering light options - with and without the camera. There's no reason why you shouldn't be able to use their lights. I have a 2025 Big Bend with no camera and had them install my letter lights and it's connected to one of my aux switches. I love them! Don't forget to use the 20% off coupon code and use your Ford points!
helifino16
Ron
Mount Sinai, NY (Long Island)
Look at the @ORACLE Lighting back-lit lights - they also offer a neat startup sequencer. There were very few options when I got mine. They install individually and do not interfere with the Camera.
Ford Bronco Grill letter lights Oracle Grill
also available in white (as well as white or amber backlit)
JTAIRBORNE
Tennessee
I looked at Oracle and Putco. Went with the Putco. Easy install and can change from white light to amber in less than a minute. Bought mine through 4x4TrucksLEDS. Included an add a fuse. Installed over a year ago. You do have to remove the grill and drill out current letters.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Heads up. The letters Ford sells do NOT have 2 brightness levels. They also connect to the upfitters. AND they don't have the animation startup sequence.
They are made by Putco but they are a different model. Putco is officially licensed by Ford and makes 2 versions of this kit. The BETTER kit I linked down below which has all the extra features.
If you want the full kit that works on all Broncos (except Raptors) and connects so it works automatically when you start your truck with all the extra features, get these: https://www.4x4truckleds.com/putco-luminix-ford-bronco-led-grille-emblem-for-2021-ford-bronco/
We have them for trucks with Front Cameras and Without Front Cameras
Ford Bronco Grill letter lights Photo Aug 15 2025, 3 06 58 PM
Archerman907
Kyle
Idaho
2025 2DR Badlands SAS Desert Sand
I bought the ford version and took apart the wiring harness. The lights have the same wiring setup, with wires to customize color, brightness, etc depending on which wires are connected. For whatever reason, the ford version has half of the wires cut about a quarter inch from the lights and the harness only covers the two remaining wires.
I was able to splice together the cut wires to a spool I had and follow putcos installation guide to regain those features back.
OracleLights
New Orleans, LA
www.oraclelights.com
If you're looking for an easy way to add some extra visibility and customization to the grille, we do offer LED Letter Badges that fit the Bronco grille letters. We have them available in both black and white, with amber or white-backlit variations. They're a nice option if you're looking for something a little different than traditional grille lights while still adding some extra lighting and style to the front end.
You can check them out here: https://www.oraclelights.com/collections/led-letter-badges
And for any Bronco6G members, feel free to use code BRONCO10 to save 10% on your order.
Squatch
Is it only white or amber? It seems like we should have OLED rainbow sequence letters by now.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Illegal to have anything but amber or white forward facing.
OracleLights
New Orleans, LA
At the moment we only offer white and amber!
