GoRhino D6 Steps and Mudflaps, Anyone done it?
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
these look awesome. Do you have something else mounted to the pinch seam?
do these mount to the wholes in the seem and where OeM steps are mounted?
Thanks
They mount on included brackets to the same holes in the pinch welds and body as the oem rock rails did. I used xpel liner tape to protect the pinch weld seam.
Bt_ostate
Oklahoma/Colorado
Sorry to pile on.
Will the GoRhino D6s work with the Ford $50 mudflaps?
thanks
Not sure as those flaps have to be modified to work with sasquatch pkg if you can get them to and dont provide near the protection, nor do they allow you to easily remove the bottom half of the flaps when you need the clearance.
CyberOrangeBadlands
Joe
Long Island, NY
‘22 Bronco
I’m also thinking about doing the Gatorback mudflaps with GoRhino D6 steps.
Noob question of the day . . .
My 2 door Badlands comes with Rock Rails. Do those have to come off before installing the GoRhino D6 steps? Or do the D6 steps somehow attack to the rock rails?
Bt_ostate
Oklahoma/Colorado
Have to remove the rock rails for the boards as they replace them. Don't have to remove for the mudflaps, but be sure you get a front set made for rock rails. They have two different front sets. Those designed for rock rails have a cut out in them to accommodate the rails.
CyberOrangeBadlands
Joe
Long Island, NY
‘22 Bronco
Don't have to remove, but be sure you get a front set made for rock rails. They have two different front sets. Those designed for rock rails have a cut out in them to accommodate the rails.
K - thx BT
Asked customer service at GoRhino and was told these steps will not be available for 2 door until late Spring.
RyanP
Ryan
Maryland
Mazda CX-9
DSS with Ford mudflaps. No cutting required for the step. Cutting required for fenders w/ Sasquatch.
looks amazing. (I ordered the IS too.) how's the step in height and is the DSS wide enough to step on / in comfortably without hitting your foot on the door sill area?
vegetarianbarbarian
Ara
Novato, CA
2021 Ford Bronco 4dr
Yes you have to remove the rockrails to install the D6 steps since they use the same mount locations. So it's one or the other. The D6s would be a step rather than much of a rockrail, would be my guess.
Bt_ostate
Oklahoma/Colorado
Correct. Mudflaps can be installed with boards or rails in place. If you install d6 boards, they replace the rock rails so removal is required.
Bdockins
Ben
Ga
1990 F150
Bdockins
Ben
Ga
1990 F150
Hey thanks!
Man those are sweet. Seem to really cover the pinch welds too
Also. Says additional parts needed from Ford for install .. ?
RClark82
Ryan
2001 F150, 2008 F150, 2021 Bronco
I would prefer it a bit wider as a step, but it's perfectly useable. The vehicle is my wife's daily driver and for her smaller foot it's great.
I would rather have the vanity of the smaller step than the function of the wider one.
