Good road tire without an aggressive tread pattern - recommendations?
razehound
SoCal
2025 Bronco
Yokohama Geolandar A/T4 should work nicely for what you want without going all the way to an AS
Ford Bronco Good road tire without an aggressive tread pattern - recommendations? 1784678822997-bk
Desmolicious
SoCal
2025 Bronco HE, MX5
I dunno. I just can’t wrap my head around owning the most awesome vehicle known to man-kind, and then wanting to put Toyota Corolla tires on it.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Or mudflaps...😂
23OBX2.7
AB Canada
2023 Bronco
Similar story ... the bridgestones that came from the factory on my Base (16" , unsure of the exact tire model ) have been great year 'rounders. They stick in the rain, do OK in the snow ... the gravel roads I get on, all tires end up throwing stones, so I don't know what to tell you about that.
Michelin has a LTX that gets very good real world reviews, one of which was out of Colorado that has always stood out to me. The guy really detailed his experience with those and other tires over the years. He was really impressed with the LTX's especially considering how mild the tread pattern looks.
As I recall, the guy posted the review on a Tacoma or similar forum.
I'm fairly certain it was the LTX M/S model, not the AT version .. either of which is still pretty mild.
I had the LTX takeoffs and removed them after 4 mths for Destination XT E 275/70/18 which ride as smooth or better especially over high frequency chop cracks etc. Changed just because XT looked better. Couldn't sell LTX to gifted them to tire shop guys which means you can probably get a set for $400 as take offs. Very good tire if don't mind the tread. They may have a newer version out now that looks better.
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
Not a direct answer to your question, but good mudflaps will solve your paint chip problem. I’m a sponsor on 6G and I have a ‘23 Badlands 2.3 MT with the Goodyear 35s. I’ve done 18K miles so far with a lot of off-road gravel and have even done the Rocky Gap trail (solo) which is one of the Jeep badge trails in Red Rock. No rock chips! For your spec, Broflaps are “no drill” and even just a pair of long flaps on the front will cure it. Made in USA broflaps.com
Are they really needed on the rear? I have an OBX SAS with the plastic steps. I would think just the front would throw rocks.
justzukies
justzukies
Justus
Grand Junction, Colorado, 81503
2023 Bronco Big Bend 4cyl w/Sasquatch, 2007 Nissan Frontier V6 w/lift
Thank you all for the advice on the tires I was looking for. I went with a set of Continental ATs with a slighty aggressive tread. They are a heavy duty tire, but I tow a trailer with my Bronco, and feel confident I'm not putting to much pressure on these. They ride comfortable at the lower end of tire pressure recommendations. I pump them up a little more when towing. AND they are not picking up and throwing all my gravel driveway on the rocker panel and lower doors. Now, onto a rant about torx head bolts holding the rim rings on. Worst invention ever. Been rounding these heads out going back to my 2000 Siverado when I first encountered them. I try to be super careful and maybe it's just the cheap steel used, but I absolutely despise these things.
justzukies
justzukies
Justus
About the mud flaps. First thing I put on. A set from IAG and would recommend their products to anyone. Also a no-drill option, and their brackets seem well built and engineered. Helped, but with the number of rocks I was throwing they just weren't enough. I don't like broken or chipped windshields and I'm sure the other drivers in my line of fire don't either. So they were definitely a great addition.
