Not sure yet If the 4 Dr's have the same bolt holes, please check ! and the 2drs don't have soft tops available, (yet)Anyone try this with a soft top yet?
4dr soft tops have the same holes, I'm just wondering if the top will clear going up/down. I may give it a shot at some point this spring if no one else does.Not sure yet If the 4 Dr's have the same bolt holes, please check ! and the 2drs don't have soft tops available, (yet)
I'll stop at the dealership and measure how much room there is...especially when folding the top.4dr soft tops have the same holes, I'm just wondering if the top will clear going up/down. I may give it a shot at some point this spring if no one else does.
The 4 door holes are in a lower position...4dr soft tops have the same holes, I'm just wondering if the top will clear going up/down. I may give it a shot at some point this spring if no one else does.
10mm and 1.5 pitch.What are the size of the threads in the roll bar?
That is a great location for a hi-lift. out of the way so it does not take up space that would be used for other things yet easy to get to.Sorry to bump this from the past, but special thanks to BigMeatsBronco for coming up with this idea for the 48" Hi-Lift jack. One thing I didn't see mentioned was that you do need to drill a hole in the top of the jack head, as there is no hole there from Hi-Lift. Simple though.
