Where are you putting your harbor freight offroad jack? This thing is massive
I had contemplated removing the massive muffler and build a mount of some sort. I haven’t thought it all the way through yet. I did pick up a muffler eliminator.Where are you putting your harbor freight offroad jack? This thing is massive
NOT where you're s'pose to lift with the factory jack...On board scissor jack works just fine
Dang that looks sketchy AF. At least carry a small 2x6 to put underneath the jack so you have a more stable base. You may also want to review the owners manual for proper jack placement.On board scissor jack works just fine
It was solid, but already have added a block of wood to the boxDang that looks sketchy AF. At least carry a small 2x6 to put underneath the jack so you have a more stable base. You may also want to review the owners manual for proper jack placement.
Back on topic, I think most people just throw the BL jack in the cargo hold and don't permanently mount the thing.
I saw that. Hoping for more idea
I lift vehicles by the axle whenever possible or the swing arm . If you raise by the body you first have to fully extend the suspension before wheels lose contact with ground meaning a jack with at least 2 ' longer lift.NOT where you're s'pose to lift with the factory jack...
And if youre not on perfectly level ground...?
