Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Very clever and way more discrete than the zippers. With all the surfce area of this adaptor plate did you try any VHB double sided tape instead of having to drill into the handle? Just a thought or maybe a possible solution for anyone thsat doesn't want to drill into their handles. Then they could'nt say it voids anything. LOL.
GearShade
GearShade
William
'22 Big Bend, '19 JLU Rubi, '07 JKU Rubi, '04 F350
JUST DID, does not work. The handle is made from 30% glass-filled nylon. Nylon is hard to get things to stick to it.
Dom
Dom
Phoenix AZ
Ahhhh, thank you for trying. What about molding a slip on adaptor instead?? So it slids over the latch handle? Again, I'm just throwing ideas out there for you if some people do not want to drill into their handles.
GearShade
GearShade
William
Thought about that, but the force needed to turn the lock with the allen is a lot. Every test we did with plastic ended very badly. The allen would end up slipping the hole.
  • Like
Reactions: Dom
Techun
Pa
BD, 2.7, MIC, 4dr
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
I have the same one. What are all the zippers for?
There’s a lot of use for the zippered pockets…
-bungee storage if not keeping your gearshade in full time.
-daughter keeps her spare hair tie in there.
-parking garage ticket storage
-sunglass holder if you have aux switches and no where to put your sunglasses.
It’s an extra compartment for little things that may fly off it you have your top/doors off.
mtap
Mervin
Cape Coral, FL
Accessing the knobs for the hard top
No zippers to access the latches. The zippers are wth the front two corners for storage. All latches are accessible except the 2 center ones where there is a grommet and you will need an Allen to twist. Gearshade made a plate for those two latches so you can use an Allen key..
Ford Bronco GearShade Mesh Top HARDTOP VERSION! 271F2DB7-13C7-43FD-AE91-4F2764B4214D
Ford Bronco GearShade Mesh Top HARDTOP VERSION! 20319F16-FBB8-416D-BA1B-2FBC4C5D8101
Huff
Noblesville, IN
GMC Yukon
I think your referring to the GearShade Sun Shade and its pockets. I get those and they make sense. I like the product.
I was referring to the BestTop version that has giant zippers that dissect the entire top. Someone answered my question, they are for hardtop access.
mtap
Mervin
Cape Coral, FL
My apologies. I missed the Bestop comment.
SasBLSven
Steen
Kearney, NE
2017 Audi Q7
Y'all asked for it, so here is our offering for a solution to use the hardtop and the mesh at the same time! Will work for the 4 Door and 2 Door! 😉
NOTICE: This will require drilling into two of your hardtop twist locks.
Installation is very easy. Basically, you will remove the 2 centermost twist locks and install our stainless steel plate add-on. The mesh will have two grommet holes for an 8mm T-handle Allen wrench to pass through. You will use the Allen wrench as a "key" to twist the locks to open and close.
Your top warranty is most likely void now. :eek:
Kit contents:
  • Left stainless plate
  • RIght stainless plate
  • 2x M4 nut and bolt set
*Long 8MM t-handle wrench will be available separately, still sourcing them....
Installation:
Time 10mins
-Remove front panels
-Remove twist lock from the panel with your Bronco OEM tool kit.
-Please plate over the twist lock (clamp it in place) and drill two 4mm (3/16") holes through the holes in the plate
-Install provided M4 nut and bolt through the plate into the handle
-Reinstall the twist lock into the panel
Operation:
Full instructions will be added to our site soon.
*Removal of the front center bungee and clips is necessary while the hardtop is on. When you remove the panels, reinstall the bungee and clips.
The remaining twist locks and latches will be accessible from the edge of the mesh.
This product will go live next week! Visit www.gearshade.com for updates.
If you already have a soft-top version, we will be making a kit to retrofit it. 😉
Does this just cover the front seats or extend all the way to the back? Would like to see pics with the complete to off on a 4 door
SasBLSven
Steen
Kearney, NE
2017 Audi Q7
Nevermind, I found your page and saw pics on there. Amazing, your on my list of stuff I need/want.
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
@GearShade what is the forum discount code?
