Garage size requirements
AlienHunter
Alien
Mid Atlantic region
When my 2025 OBX 4dr w/Sasquatch arrives will I have enough room in my garage to hanger it? I currently have a 2022 Maverick in the center bay with walk around room to spare. My garage is only 20.5’ deep wall to door. My workbench takes 2.5’ of that. If it’s tight in one of the other two bays then the Maverick will have to relocate.
Has anyone measured Length/width of their Bronco 4dr w/Sasquatch?
Deleted member 64921
Guest
Super easy to Google it - takes maybe 5 seconds - 190" length - give it a try for the width 🙄
CalvinT
Calvin
Phoenix, AZ
This.
BigFootie
Wisconsin
In the old days, you made it fit! My dad’s 57 Ford Fairlane Skyliner was 2 inches too long for the garage. Problem was solved with the skinny pedal on the right. Two large indents in the wall and the door would close!
in this case, maybe a spare tire delete kit.
Varska
James
Northern IL
2025 Bronco
2025 OBX SAS checking in - 15' 10" long w/ spare. 7'9" wide with mirrors out. Folding them in only buys you a few more inches because of flares.
Oldhippie
Barry
Santa Cruz, Calif.
everyone needs a bigger garage….I know I sure do!!!
MayhemMike
Mercury
Build the Garage aka “ car hole” first then fill it with vehicles.
Ford Bronco Garage size requirements IMG_2066
Height. Don't forget the height. Especially once you start eyeballing bigger tires. Mine won't clear the garage door.
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
This is true. Height could be an issue especially if you have a roof rack. My two door Sasquatch barely cleared the door (standard 7’ tall door) with a factory rack. Anything taller wouldn’t fit.
Oldhippie
Barry
Santa Cruz, Calif.
