Forward drive shaft boot defective
Boltstop
Rudy
Idaho
69 Bronco 302
Picked up new 2 door Wildtrak with 9 miles on it on 9/28/23 . On 9/30/23 I rolled underneath to admire the fox suspension and noticed grease splatter in and around the front drive shaft boot ( part #mb3w-4a376-be m210 front drive shaft ) upon closer inspection found the boot to be separated at the second crease and grease splatter everywhere. droped it off 10/02/23 in the morning just got word they don't have the part and don't know when they will get it could take days or weeks I assume that part is wildtrak specific but who knows . I've searched the 6g forum and can find nothing on this issue to me it looks like a factory defect . By the way I love the 2 door wildtrak it's a beast
Ford Bronco Forward drive shaft boot defective Resized_20230930_113326
Ford Bronco Forward drive shaft boot defective Resized_20230930_113407
Ford Bronco Forward drive shaft boot defective Resized_20230930_113633
Ford Bronco Forward drive shaft boot defective Resized_20230930_113454
Ford Bronco Forward drive shaft boot defective Resized_20230930_113519
Ford Bronco Forward drive shaft boot defective Screenshot_20230930_114916_Brav
PWillette
Parrie
Maine
That sucks man. @flip may be able to confirm part availability.
JT58Bronc
JT
Fl
There was a TSB or recall on the front driveshaft on some 2021's maybe taking a lot of the inventory. Mine was an early 2022 build and had a defective front driveshaft- the grease caked and dried on the inside of the boot and created a screeching/whining noise. The exact same symptoms described in the TSB or recall. Maybe a 2021 driveshaft used in my build who knows. My dealership was able to find one at another dealership fortunately but that was a while ago.
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
I traded in my 23 black diamond when I got the wildtrak and they gave it back to me as a loaner while they figure out the axel problem . I will say they wanted the wildtrak in asap to fix the problem . I'm glad I got under it or I may not of found it befor it failed
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
flip
Phil
IN
www.ruxerparts.com
Fords
DM it to me if you'd rather not disclose. I can't search without at least the last 8.
Ford Bronco Forward drive shaft boot defective 1696354188788
flip
Phil
IN
www.ruxerparts.com
Fords
I don't think you can get just the boot based on what I see in the catalogue. There're a shit ton of front driveshafts available so getting one shouldn't be an issue.
Ford Bronco Forward drive shaft boot defective 1696355600308
Ford Bronco Forward drive shaft boot defective 1696355667914
PWillette
Parrie
Maine
So if you tear a DS boot you need to replace the entire drive shaft...wow
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
So are the front drive shaft the same for all trim packages or are some heavier duty than others ?
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
Just got word they will have the part in 4 days hopefully it won't take long to install
timhood
Tim
Several
It depends on how soon it's caught. Generally, they inspect for damage and decide. If water and road debris get in there, it doesn't take long to make a mess of things, especially if any part loses grease protection.
timhood
Tim
Several
That must have felt weird. Did you apologize to your Black Diamond for turning it in to the shelter? 😁
Dude1967
Billy
2025 Ford F150 Tremor
Takes very little time to replace, dropped off at lunch and done by 4pm.
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
Yes YES Idid lol
