Forscan change Recirc button?
dgorsett
colorado
F250, Mustang, Explorer
It seems when using AC it will stay on, w/o AC on it won't. I actually don't like recirc and would prefer it to be off in AC. I have to manually shut it off at each start w AC on.
Longbow
N NV.
Blue Badsquatch
Well here its dusty almost year round and currenlty experiencing forest fire smoke, which has become a yearly event it seems. I wonder if the emergency services (Fire, ambulance) area in the programming would help?
Gtrekker
Gary
NJ
Anybody know if I can change the way the recirculate button works with Forscan? I want it to stay on when I turn it on. Right now, it randomly turns off - usually when I directly behind a diesel truck with his foot on the pedal!
I found if you just use AC and not Max AC it will remain in fresh most the time unless you use auto start from the fob or app.
Big Rig
2001 Silverado 1500
Jumping in on this because it is seriously annoying. Tons of wildfire smoke right now and the recirc will not stay on no matter what. Seriously need a way to change this.
JP_Oracle
JP
Metairie, LA
21 Bronco
Only workaround I’ve found is to set the temp to Max AC then you can turn down the fan and it’ll stay on. Will turn back off if you change the temp though.
Bigguyry2000
Ryan
Southern California
2021 Black Diamond
It would be nice to have the option on a dusty trail, in a big line of vehicles, to leave the recirc on. One of the plusses of the bronco is that it is sealed up pretty well and won't get dust everywhere in it if you keep the recirc on. Maybe ford can OTA update that or something.
a143gsxr
Stephen
South Carolina
Just bought my bronco and immediately went to two different Ford dealerships asking service how to fix the recirc to stay on and they both had no clue. I jumped in the forums and found this thread. I started a case with Ford yesterday. This should be a simple fix in programming once Ford gets to it. At 75mph without recirc on its loud and windy in the cab. So dang annoying.
Ksjrb03
Tx
F250
Don’t hold your breath. There is nothing to fix, it working exactly as designed, no matter how annoying it is.
a143gsxr
Stephen
South Carolina
Ford can change the A/C control module programming to stay on Recirc with an update. They just need enough of us to say we don’t prefer their current programming. So there is most certainly something for Ford to Fix/change.
Ksjrb03
Tx
F250
Nope. It’s done for safety reasons. Will not be changed.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I thought I was losing it when mine did this since my mustang never did. It def has to do with that under 60 degrees thing someone else posted
t3n2and4
VJ
Washington
www.instagram.com
Badlands, F150, VW CC
It’s definitely annoying. It barely stays on a minute at a time.
So as fall proceeded I experimented. I know now that if the outside temp reads 61 or above - Recirc will stay on unless in window defogger mode only.
Any time below 61… which is nearly all year here, turns off in 1 minute. Wildfire smoke at 54? Tough sh*t. Diesel? Too bad. Dusty trail people ahead of you? *HA HA*
1 minute is wildly inadequate even for a traffic light in most cities.
