Deleted member 19285
Guest
Hey, I've been using your ST and Hubitat apps for years. Great to see you here.
Now I realize I'll need a Bronco-Hubitat integration.
tonesto7
Anthony
Ann Arbor, Mi
2021 F150 Lariat 502A
New Release: v2022.02.21.0
I just pushed out a new release which hopefully gets the large widgets working more consistently.
Please let me know the outcome!
4XMORE
AJ
OC
Ford Raptor
How do we install the update?
wesk1318
Weston
Atlanta GA
2022 bronco
So when you are using the app and want to unlock the doors for example, you click on the unlock in the widget but then it opens the scriptable and asks again to unlock?
Does it not just unlock the doors via the widget and not have to open the scriptable app?
Also the image did not load?
Indica
Alek
Illinois
‘21 Big Bend
@tonesto7 Thanks for making the recent updates! My Bronco’s picture is showing now.
Bbaliatico
New Jersey
2022 Bronco
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
Following instructions, but when i hit play on the script to install the widget, it gives me an error - " 2022-06-14 14:09:42: Error on line 15:70: iCloud is not supported. Make sure that you are logged into iCloud in the device settings."
any suggestions? I am logged into icloud
tonesto7
Anthony
Ann Arbor, Mi
I've heard others mention this before. You will need to go into iCloud settings under iOS and make sure Files and Scriptable are both toggled on.
faziorf
'21 2DR OBX AMB
I saw this SSM come through https://static.nhtsa.gov/odi/tsbs/2022/MC-10212957-0001.pdf
“Some 2013-2023 Ford or Lincoln vehicles with modems activated through FordPass or LincolnWay may experience 12 volt battery drain symptoms when the customer uses non-Ford/Lincoln phone applications as an alternate channel to access vehicle commands such as door lock/unlock, remote start, vehicle location, etc. The battery drain may be caused by excessive calls for data through the vehicle network keeping it in an activated state.”
@tonesto7 Does this effect you at all with the app? You getting pressure to take it down?
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
So I’ve gotten to the part where it asked to select my vehicle, and I am only able to choose our 2021 Bronco Sport, my 2022 Bronco does not show up.
bytheway
Brice
Louisville, KY
My script was broken for a week or two. I think the new Fordpass updates had it screwed up. The script updated yesterday and it was fixed. For anyone who had the same issue, try updating to newest script (7.04)
Tortuga353
Laguna Beach, FL
Mines not loading images based on my Vin.
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 1663383520388
Agrod
SJ, PR
22 4dr OBX
I haven’t been able to get this to work. I get the login prompt, but it keeps showing the region as NA. Afterwards, I get the following message:
Ford Bronco FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 23EA7269-0DEF-4561-9E85-06B11F73B194
Any help appreciated.
EDIT:
Found that this issue was already reported in GitHub, and it may be because of a change to the api token auth:
https://github.com/tonesto7/fordpass-scriptable/issues/127
mcinfantry
Lee
Louisiana
Badlands 2 door
I can’t either
King_Bronco0327
Orlando
Description:
What's New in V2:
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
    • Widget updates
    • Deep Sleep Mode
    • Firmware Updates
Updating from v1:
Giving Thanks:
I noticed that tesla has a locked screen widget where it shows the state of charge of your car. Is there the same but with this?
