tonesto7
Anthony
Ann Arbor, Mi
2021 F150 Lariat 502A
Yep. This widget combined with the Siri shortcuts (available elsewhere) mean that I rarely use the FordPass app.
I have the widget set up to parse voice commands from a special Siri Shortcut.
I just need to build the speech-to-text parser so you can ask questions and execute commands. This will be in the next major release.
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
@tonesto7 I’ve been using v1 since you released it and I use it every day. Stoked to see this big update! A couple things: my widgets won’t load the info image but the script works. Your discord link seems to be dead, and I sent you a small donation for sharing your work. Thanks dude!
4XMORE
AJ
OC
Ford Raptor
That's awesome! Hey some of us are having issues running the large format widget. I reported it on GitHub for us. Is there anything easy we might be forgetting to do that is cause us issues? The medium one works.
RunninRiot
Brock
Boulder, CO
2021 Bronco Badlands
^^^This^^^
How do I make a Siri shortcut to start the Bronco? I could only figure out how to make her open the widget in the scriptable app.
I googled it and there is a link from the Bronco Sport forum to the updated Reddit thread. Took me all of 15 minutes to get it working. I’m living in the FUTURE now! It’s super cool.
De Brus
De Brus
Washington state
That’s the same way I used to set it up also. The developer is still active and fixed a major bug a few months ago. Here’s the link for any one interested
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
You are clearly a genius as you are macOS and Bronco headed. My hero. Thanks muchly.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
I fcking love you!
Thanks! That probably saved me three hours of banging my head up against a wall before finally giving up.
Mirth
Robert
Watertown
2021 Bronco 2 Door
Thanks that was a fun way to spend an hour on a snowy saturday, everything seems to be working great
BD1
BD1
IL
Description:
What's New in V2:
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
    • Widget updates
    • Deep Sleep Mode
    • Firmware Updates
Updating from v1:
Giving Thanks:
This great….easy to setup.
THANKS
USAGUY
Ny
. Very cool. Way to much for me to do. I can’t even figure out how to get Ford pass on my wife’s iPhone. Does anyone know if you can have two Ford passes on one vehicle. If so…….How? When I scan the Vin for my wife’s iPhone it tells me sorry vin is already in system. Gotta be a way
Michael Grasso
Indianapolis
2025 Ford Bronco
Giving Thanks:
Once we've done all this how do we add it to the widget section of Iphone? It doesn't show as an option...
Tmkimler
Tyler
Phoenix
2022 Badlands, 2021 Explorer
Been using this for awhile now and love it. Thank you!
Any chance to be able to do 2 cars? Have an explorer now and getting the bronco soon
tonesto7
Anthony
Ann Arbor, Mi
Use the widget tool to create a second instance and set it up for the explorer.
